This original post is a few years old but in case it’s of use to someone else, I have exactly the same issue, clear water leaking from the underside at front left corner. In my case it is the rubber tube connecting the soap drawer to the drum. At start of wash and during rinse iwater is pumped into the soap drawer then flows via the rubber tube to the drum. The tube is articulated and stretchy but for some reason the top connection the the soap drawer works loose. I’ve replaced it once and it’s worked loose again a week later. I’m off to check is the drum springs and support arms are allowing the drum to move around to much and wrench the rubber tube off in the process. Anyway hope this is useful to someone.
