Re: Melting of moulded plug on Condenser Dryer model VHC 180
This is more often than not due to a faulty wall socket rather than the plug itself. Any loose or poor connection will cause overheating and worn contacts inside the socket are not uncommon.
I find it hard to believe that it’s the socket as my water boiler used to be plugged into it and has worked without any problems. I only unplugged it to use the tumble dryer. Thank you for your response
