Ray Thornton
ParticipantOrdered this one
https://uk.farnell.com/oeg-te-connectivity/omi-sh-112lm-394/relay-spst-no-250vac-30vdc-10a/dp/1891750It’s rated as 16a on the pdf, I will test on the bench first
Ray Thornton
ParticipantI got it back from the repair guy, took the pcb and removed the relay
It’s a MPL-112-A-T meishuo
Any idea where I can source one quicker tha ebay but based in China?
Is there a alternative I can use?
ThanksRay Thornton
ParticipantThanks Dave,
I found it, checked for dry joints but found none, chucked it at the local repair bloke
Back at work tomorrow do can’t spend too much time on itRay Thornton
ParticipantI have given up, took it to our local friendly repair guy in town
Ray Thornton
ParticipantDay off today and just tested the door wires, they are all OK
I have the pcb exposed, what should I look for now please?Ray Thornton
I realise I’m a numpty
Is the main pcb in the door?Ray Thornton
ParticipantLet me start again…
I assumed it was the heater element, so I ordered another and fitted it yesterday, the old one looks exactly the same, I have not used a multimeter as I can’t find it.
The dishwasher works fine as to the programs but no hot water
I realise I should have tested it, but I assumed what it wasRay Thornton
ParticipantI’m at work today, the machine works as it should, cycles, uses salt etc but will not heat up.
I’m assuming that any pressure switch would be ok
Where would the pcb be? In the door where the buttons are?Ray Thornton
ParticipantA job for another day me thinks.
Thanks very much
RayRay Thornton
ParticipantWell it working with no water where it should not be, but its still not heating up
Any ideas?Ray Thornton
ParticipantThanks, my first go at a dishwasher
Ray Thornton
ParticipantThanks, just put it back and had a leak and code e4 again, it did start the washing cycle then leaked, Saturday evenings are meant for this!!!
Just pulled it out and going in againRay Thornton
ParticipantUnder pressure and unable to fix it quickly, we are now the owners of a Samsung washing machine
Thanks for the advice RayRay Thornton
ParticipantThank you,
