Reno_1ted
  • Reno_1ted
    Re: IGNIS ADL 334 fitted dishwasher fault – flashing light
    All done and dusted, and dishwasher works fine. I just need to get it back under the worktop and raise the height again. Fitting the part was pretty easy once I managed to get the bottom panel off.
    Thanks SO much for the help, I would have had no idea without your assistance.
    The element on my grill blew the other day as well (I am waiting for the washing machine to go, as it usually in 3’s they say!), so once i get the specs I will be checking out that part of the forum !! 🙂
    Thanks 10000000 again !
    Reno_1ted
    Ok.
    I got the dishwasher out, and snapped the water feed pipe, water everywhere but nothing a mop and some cursing didnt sort. Next time, i will switch the water off as well as the power! Whoever fitted the kitchen fitted this with the shortest pipe ever.
    So i need to get a new pipe for that.
    Anyway, i got into the bottom section, which seems to have a fair bit of water in it. And a black rubber pipe that connected to the middle was hanging off. So i need to get a jubilee clip for that to, any idea what size it will be? Could that be the cause of the problem?
    Anyway, i found the bit and unscrewed it, the part looks the same except the connection for the wire is a lot smaller on the old one then the new one, the new one came with its own wire, so will that fit in the “junction box” end ok, or will that be a smaller size to?
    Also, i couldnt get the bottom panel fully off, it was like it was stuck on the “junction box” (what i call the bits where all the wires lead to). Does it come all the way off?
    Many thanks from the wet kitchen ! 🙂
    Reno_1ted
    Cheers!
    I have ordered the part and will keep you posted as to how I get on. I will of course power off before I start. 🙂
