Rob Bell
  • in reply to: Dishwasher element & thermostat faulty the same time. #474972
    Rob Bell
    Dear Dave, The water overflow (E4 error) was fixed by re-tightening the heater rubber hoses clips. Ran a dish wash program and the new heater worked ok (no E3 error), however a small leak appeared under the washer. After much thought my hunch was right – Initially ran the washer without any trays inserted, I inserted the top tray and this time the program completed with no leaks. Without the top tray the water ejected straight out onto the door (instead of into the spray arms) causing a small leak out the door seals. Thanks for your helpful advice it saved me forking hundreds on a new washer. – Rob
    in reply to: Dishwasher element & thermostat faulty the same time. #474971
    Rob Bell
    I guess I have no other option but as you say remove the side panels.
    in reply to: Dishwasher element & thermostat faulty the same time. #474969
    Rob Bell
    I fitted a new heater (which has a new pressure switch) put it all back together but:
    On running a program you can hear the water enter then you can hear the water inlet stop and then the soap dispenser catch open
    but straight after the E4 error(flooding) alarm is sounded. Then the water is pumped out but program is stuck with E4 sounding. Looks like there is a water leak
    somewhere that fills the bottom tray and quite a lot of water ends on the kitchen floor. I checked the heater rubber hoses and the new jubilee clips I fitted but
    they look good and do no seem to leak. I wonder if it has anything to do with the fact I had the dishwasher upside down.
    in reply to: Dishwasher element & thermostat faulty the same time. #474967
    Rob Bell
    Thanks for the link that is the very element I want. I assumed the thermistor is on the side – it has two terminals (you can only see one in the photo) separated by black insulation tab.
    in reply to: Dishwasher element & thermostat faulty the same time. #474965
    Rob Bell
    I agree the heater is faulty and yes you may be right it could be a thermistor. Tested the thermistor, as you said, I tried all the ohms settings but the meter reading never changes, stays at value 1 (on the left hand side). I cannot put my fingers on the thermistor as the sensor is tucked in a recessed tube. So guess that means the thermistor is also faulty and strangely the same time as the faulty heater?
    in reply to: Dishwasher element & thermostat faulty the same time. #474962
    Rob Bell
    I set the meter to 200ohms scale and in testing both the heater and thermostat there was no reading change (display stayed at 1 )
    in reply to: Dishwasher element & thermostat faulty the same time. #474960
    Rob Bell
    I did the ohms test and the readings did not change. I could change the unit but I am wondering why both the heater and thermostat are faulty at the same time?
