rob_bot
  • in reply to: Loud ‘cracks’ on a wash cycle on SMEG DWF 64 SSE #225933
    rob_bot
    Re: Loud ‘cracks’ on a wash cycle on SMEG DWF 64 SSE
    Well it seems to be the surpressor/tri capacitor (grey cap on the lower LHS behind the lower panel).
    It is spilt down the side and the top has been blown off.
    Can’t see that part number Penguin45, just 70092 and the values of the caps; 0.1uF x2 and 0.0027uF x2 written on it.
    If this is the part then I will order.
    in reply to: Loud ‘cracks’ on a wash cycle on SMEG DWF 64 SSE #225929
    rob_bot
    Wow, fast!
    I will take a look under the cover and let you know/order the part.
    I need some bits for the rs21dcns Samsung too (defrost heater/water tank) can you supply those as well?
