Ryan M
  • in reply to: Hotpoint HFC 2B19 UK – beeps 3 times when starting to fill #480688
    Ryan M
    jackel11 wrote:Parents have the same dishwasher with the same issue. Did you find a fix?
    [USER=”60873″]jackel11[/USER] I hope the above is able to help with the issue your parents are having.
    Thanks,
    Ryan
    in reply to: Hotpoint HFC 2B19 UK – beeps 3 times when starting to fill #480687
    Ryan M
    Hi All,
    I’ve had this issue for the past week, after the dishwasher was working initially. My issue was the same, where the dishwasher would attempt to fill with water, and then would flash the programme light and beep 3 times, same as the video the original poster linked (https://drive.google.com/file/d/1Y-2…YDXPKqZie/view).
    What worked for me, was checking the water inlet pipe that was installed by the plumber. Upon further inspection and pulling out the machine, the water inlet pipe was slightly bent/kinked and I assume, the reason behind why the dishwasher was failing to fill. I assume, there’s a timeout (the flashing of the lights), if the machine doesn’t receive enough water within a certain period of time.
    Anyway, I’ve fixed the issue with the bent/kinked pipe so it’s all free, and moved the dishwasher back into place, with no issues, and the programmes starting first time. The filling of water is also alot louder as it’s now receiving the correct amount.
    I made this account to comment, and I hope this helps someone. Please check your water inlet pipes first, before thinking your machine is broken.
    Cheers,
    Ryan
