Scott.robinson85
ParticipantRe: Hoover DXA43WA
It’s the time we couldn’t afford. Not the money
Scott.robinson85
No lateral movement on the impeller and the resistance test proved good.
Samsung came today so the Hoover is in the front garden waiting for the scrap man unless anybody wants it lol
Scott.robinson85
Ok well I wouldn’t have done that without performing some sort of test to prove it.
It’s alright randomly swapping parts out if someone else is paying for them eh
Scott.robinson85
Based on what?
Scott.robinson85
The battle and war is lost, she’s ordered a Samsung. Hate not getting it fixed.
Thanks for the help all the same :tup:
Scott.robinson85
Nah the machine has its own standpipe in the utility room
Scott.robinson85
Hi guys, thanks for the great reply’s. So I have had the pump off and the sump hose. Nothing inside the sump or drain hose. Blew down the small pipe from the pressure switch and it didn’t seem blocked.
I can’t see where the other end of the pressure pipe goes so unable to check for a powder goo build up.
Did a resistant test on the pump so that’s fine. The machine drains in about 50 seconds but the pump remains pumping until it throws the error code at me. It’s like I won’t stop trying to drain even after it’s drained. Had a guy out to it who didn’t have a clue. He didn’t even look at anything!
Scott.robinson85
electrofix wrote:disconnect wires from heater. make sure they cant touch and insulated
then try a rinse and spin with no clothes in
if it works change heater
Just tried that and still got the E03 error. So any other ideas from your 100yrs experience would be greatly appreciated
Scott.robinson85
I’ve only ever used to to test for power and resistance tests. I’m just regular joe bloggs. But thanks for taking the time to try and belittle me
Scott.robinson85
I have a multi meter. How would you test it?
Scott.robinson85
And the glass door does feel warm. Would the water still get hot if the heater was the problem
Scott.robinson85
Hmm, the machine will do a full wash with the soda crystals in. Won’t do a full wash with clothes in though. Maybe I’ll try with a full load in and the heater disconnected
Scott.robinson85
Yes I read that somewhere else. Is there a way of testing it?
