solder-blobby
Viewing 1 post (of 1 total)
  • in reply to: in-line heater test? #170430
    solder-blobby
    Re: in-line heater test?
    Hello Guys ,
    It’s a shame I didn’t read all this stuff before I spent most of Sunday morning dismantling my Zanussi 6855 !! Anyway, I had exactly the same problem with a dry joint on the relay terminal. Well done Electrolux!! Engineered to last – just outside the warranty period. I understand there was a press announcement – only any good if you have time to read the paper. The following link suggests the fault may trigger a ‘thermal event’ (a less alarming way of saying ‘FIRE!’) Keep up the good work………
    Solder-blobby.
    http://www.london-fire.gov.uk/fire_safety/reca … asp?id=390
