Re: Fisher & Paykel GW501 Beeping
This is actually fault code 136.
Motor Stall
The Motor Controller has been unable to start the motor. Possible causes of this fault are: Faulty motor harness, faulty or jammed motor, seized bearings or seals, faulty Motor Controller module, faulty Rotor Position Sensor or harness.
Check the motor harness, connectors and motor for discontinuity. Also check the Rotor Position Sensor and associated harness for water, mechanical damage or corrosion.
Finally Motor Controller module could be gone
