Stacey Pollitt
ParticipantMorning,
Thank you for your reply.
Quick update. I used the dryer without the condenser unit in. On 2 different settings and it worked. Never beeped and never stopped.
Would this point to me having to get another condenser unit?
Stacey
Stacey Pollitt
ParticipantHi,
So i set it going and chose the longest timed setting. It started at 110mins and got to 41mins before it stopped.
However throughout this time it beeps periodically – no lights flash. Just one beep. Then all of a sudden it beeped 3 times and stopped.
Stacey Pollitt
ParticipantAwesome,
Will try it now on 59mins.
I really appreciate you taking the time to reply.
I will come back to you either way 🙂
Stacey Pollitt
ParticipantHi,
So i tried this. Took the condenser out and it was clear however i washed this out anyway.
Tried again with some bedding and it did the same again.
Any other ideas i could try or what it could be?
TIA
Stacey Pollitt
ParticipantI will give it a go and come back to you.
Thank you
Stacey 🙂
Stacey Pollitt
ParticipantHi,
No – nothing flashes up or stays on. It literally beeps 3 times and then the time flashes like it’s on pause. If you press start straight away it wont work but if you let it sit for 5/10mins it starts again when pressed.
But does this around every 15mins through a full cycle.
I wondered if it was over heating?
