Steve-333
Viewing 1 post (of 1 total)
  • in reply to: John Lewis JLWD1408 washer/dryer tripping RCD switch #440797
    Steve-333
    Re: John Lewis JLWD1408 washer/dryer tripping RCD switch
    Thanks Kaibart, but the washer/dryer is a John Lewis branded machine. I ‘m not sure that it is a heater related problem though as it trips for drain, spin, etc programs which don’t need the dryer heater to function – but to try and eliminate the dryer heater as the cause, would disconnecting it and trying to run the machine with it disconnected cause any possible additional problems with either the machine or the machine’s PCB?…if not, do you know how I would be able to disconnect it.
