Steve Dobson
  • Steve Dobson
    electrofix wrote:when you took the covers off the fan was there any sign of ice build up
    its starting to sound like a system fault as you say the compresser never stops. its looking like a compressor fault or lack of gas both of which are specialist faults
    no ice on the fan at all, the fan has been replaced in its past and found that the wire had been cut and connector blocked back together and this was on the freezer pipe, to which i have sorted properly and now the fan error hasnt come on since,
    does anybody know the rough price to have it regassed? im in the midlands
    Steve Dobson
    electrofix wrote:correct behind the panel
    checked the fan and its working fine, any ideas how to get it colder, its set at -19 for the freezer and 1 degree for the fridge but just wont go no lower than -5 in the freezer and +6 degrees in the fridge?
    Steve Dobson
    electrofix wrote:E13 is a freezer fan error
    check the freezer fan is operating
    in this weather make sure the unit has space around it to get rid of the heat
    where would the freezer fan be?
    is it located behind the back of the freezer behind the internal panel?
