Re: Ariston A1400SWD leaking, help needed
Hi Odom,
many thanks for your reply, there was a access panel on the back which gave access to the pump and sump.
on taking the pipe between the sump and pump off, I found a hair clip which had jammed the float ball, it would seem this was stopping the float from raising and thus emptying the water in time for the spin.
Again many thanks for you reply and the fix.
Steve 😀
