steve_i
Viewing 1 post (of 1 total)
  • steve_i
    Hi all,
    I have read this entire topic with interest. I had a similar problem with my S25B, and changing the 4 capacitors did make a change to the behaviour – it brought the icemaker back to life but its valve is still clicking loudly and the water is pulsing as long as the icemaker is switched on and the doors are closed…
    Fridge and freezer are still OK. But, I have to take the plunge and get the replacement board. However – do I need just the rear board or both rear and front boards?
    Numbers are:
    Model Number: S25BRSS31-A/G
    858616615010
    110327019833
    Note that as well as the water valves pulsing, the front panel display also flashes when the icemaker is dispensing…
    Thanks!
