TH3 M0L3
  • in reply to: Electrical problem with washing machine or not? #295960
    TH3 M0L3
    Re: Electrical problem with washing machine or not?
    webmaster074 wrote:Guess it might be time to call the Candy engineer out before we call the electricial again
    Probably a good idea as the machine would be under warranty and the visit from the engineer probably wouldn’t cost anything….
    Might even pay to have an electrician attend at the same time as the engineer ??
    in reply to: Bosch WFO2866gb not turning #296372
    TH3 M0L3
    Re: Bosch WFO2866gb not turning
    Ps I have earned major brownie points for doing this
    in reply to: Bosch Classixx 1400 Express washing machine won,t spin #295800
    TH3 M0L3
    Re: Bosch Classixx 1400 Express washing machine won,t spin
    When I got back to her place and inspected the motor again it was pretty obvious as to which way the brushes sit. Thanks for your advice though.
    in reply to: Bosch WFO2866gb not turning #296371
    TH3 M0L3
    Well, the resistance of the windings was somewhat confusing as there are multiple terminals. The most I got was 1.5 ohms.
    Anyway, regardless of that, I replaces the brushes which did the trick.
    The machine even runs quieter now because I cleaned the motor out too.
    Thanks for the info.
    in reply to: Bosch WFO2866gb not turning #296370
    TH3 M0L3
    Penguin45 wrote:Meter across the motor terminals and ensure that the circuit shows 5-10 ohms
    is this the same for all terminals as there are, as you probably know, a few.
    I am used to working on induction motors as I am a air-con/chiller engineer, but don’t come across these motors at all so not familiar with them?
    Penguin45 wrote:check that the running surfaces of both are nice and shiny. If one looks dull, they’re finished and need replacing.
    One of the brushes has a silvery surface, the other not. You can see the wire in the end of the latter brush, so I’m guessing this is my problem
    in reply to: Bosch Classixx 1400 Express washing machine won,t spin #295798
    TH3 M0L3
    This thread has helped me too, just one question from me please?
    I already suspected the brushes, so removed the motor to gain easy access to the brushes. When I removed the brushes I stupidly forgot to note in which direction they sit. I’m guessing this is pretty critical, so is there a general rule, or is it motor specific?
    My issues are with a bosch WFO2866GB FD8411601609
    Sorry for poaching this thread, but it sounds like Silverbroom is my answer!
    Thanks in advance!
