thunder pants
  • in reply to: Leak from rear of drum of Bosch Exxcel #459032
    thunder pants
    Hello Dave,
    thanks for the prompt response
    it occurs to me that having got this far, I might as well replace the bearings anyway. The link for the bearing kit you included above does not list my model number, should I find a different one?
    in reply to: Leak from rear of drum of Bosch Exxcel #459030
    thunder pants
    Hello Dave,
    Finally got on the case today, bit of a wrestle but the spider is out. Removing the bearing seal is proving nigh on impossible – is there a way to get it out without knocking the bearings out?
    cheers in advance
    Nik
    in reply to: Leak from rear of drum of Bosch Exxcel #459029
    thunder pants
    Thanks Dave
    in reply to: Leak from rear of drum of Bosch Exxcel #459027
    thunder pants
    Hello Dave,
    This job was put on the back burner for a while. I’m back on the case and struggling to find the appropriate part. Been in touch with someone from UKWhitegoods who said as far as they were aware it wasn’t possible to get the seal separately, it might come with a new spider (SKU 00283726 for £200!) or a new bearing kit might do the trick. I’ve changed the bearings before – not a job to undertake without knowing it’s absolutely necessary! Any suggestions gratefully received.
    Nik
    in reply to: Leak from rear of drum of Bosch Exxcel #459025
    thunder pants
    Thanks Dave, is that a straight forward thing to repair (once the drum has been removed from the cabinet)?
