Tim.Greaves
  • in reply to: Bosch WFF2001 stops at spin/pump on any cycle #161028
    Tim.Greaves
    Re: Bosch WFF2001 stops at spin/pump on any cycle
    Hi Martin,
    Sorry, I mis-interpreted your “very likely” as confirmation that the pressure sensor/sensors were knackered and needed replacing! 😳
    I’ve just had the back off the machine to check the pressure chamber and found it was blocked up with gray chalky deposits. I gave it a good clean out and now everything is fine again. 😀
    Thanks very much for the pointers,
    Tim
    in reply to: Bosch WFF2001 stops at spin/pump on any cycle #161025
    Tim.Greaves
    Apologies for tagging on to this thread but I have a very similar problem with my WFF2001. After the main wash cycle the machine empties ok but then stops with the spin and rinse lights flashing together. I read above that this indicates a problem with the pump/pressure system/blockage.
    I’ve done some tests – basically just running the machine on a rinse cycle – and it fills, the drum turns and then empties quite rapidly but the pump goes for 6 mins. and then the lights start flashing. It never re-fills or starts spinning.
    To me this suggests the pressure system. Would anyone agree?
    If so, is this easily replaced and would anyone be able to let me know the parts required?
    Many thanks
