whitehse46@hotmail.com
ParticipantSo I’ve been barking up the wrong tree….retested amount of water pumping out was now 2 litres so went back to recheck pressure sensor and perhaps play with it as I have a spare pressure switch Removed tube again, I could blow but couldn’t suck. So cleaned out sump, full of crud…… this was intermittently blocking tube to switch, which actually operates well before 2 litre the test amount….bloody hell great wild goose chase for the obvious fault, well I have a lot of spare parts and a working dishwasher yipeeeee……. ( well foxed by when you added .5 litre it then worked ok)
So fault fixed food gunge in sump causing pressure sensor to behave intermittentlywhitehse46@hotmail.com
ParticipantOk so that hasent worked changed air brake. It’s still intermittent. Now it’s obviously thinking it’s seeing to many turbine pulses. So my guess its triggering on the positive and negative going edges. So my next visit edge connection on the controller. But it could be a fault in the 20ma loop etc . Starting to look like controller fault. Drat that’s an expensive game programmers cards and card can’t spend £180 on a 8 year old dishwasher. Perhaps a dry joint or capacitor. Worth a play here I go.
ParticipantI’ve just ordered an air brake and turbine…. Quite how it can be reading wrong I don’t know but worth a punt at 30 quid
ParticipantI said impeller I think it’s called turbine
ParticipantOk so I’ve found out more after your idea. So in test the machine is supposed to put in 2.5 litres, and then check pressure sensor. But it’s short filling ie only putting in 1.7 litres. So fails. If I open the door and chuck a cheeky litre in to fox it its happy and runs. Hence fault is not pressure sensor it’s pointing more at impeller. Checked water inlet filter and tried reducing pressure at tap still short filling will look at replacing impeller next what you think….
ParticipantNo occurs on normal cycle. Happening about 1 in 3 washes. And sometimes fails on test. I will check output hose for syphoning next but unlikely. Then I will check connector on circuit board. Machine still washes which sort of is weird that it does a fill a rinse a fill and a wash and then fails on hot rinse and pumps out
ParticipantPipe cleaned and pressure sensor changed oh no still intermittent
ParticipantOk so I understand so much more already. When I run test mode I get alarm 1+3 which apparently says 2.5 litres of water added not detected. So I will try cleaning pipes and checking pressure switch. Any other suggestions or hints
ParticipantAn interesting read. I am on here cause I have identical situation. On my machine the fault is intermittent but occurs 75 percent of the time. Have you had any luck. I was wondering if a temp sensor was saying it’s hot when it’s not etc…..
