winth_e
  • in reply to: SMEG slimline DWI45.1 unlisted error code #144680
    winth_e
    Re: SMEG slimline DWI45.1 unlisted error code
    Thanks Dave!
    I found the trip and reset it …the dishwasher seems to be running ok …for the moment! I guess if it keeps tripping then there’s an underlying fault.
    Eddie
    in reply to: SMEG slimline DWI45.1 unlisted error code #144678
    winth_e
    Thanks for the reply. I really appreciate your input.
    I think I’ve got the right error code now: it’s actually “E3”. However, if the unit is switched off and back on, you get the two right hand lights flashing – as described in the thread “Smeg DWI45 slim line dishwasher”.
    (I normally run my unit on a time switch to take advantage of Ecconomy 7 tariffs. So in practice the unit has run, given the error code, the power has gone off, then back on, then we get the situation where the two LEDs flash – confusing!)
    So it looks like I got a potential heater element problem?
    Just for clarity. Is the reset/trip underneath the unit (not inside the washing cabin)? Should I be able to reach the reset from the front? (‘cos I can’t see anything obvious), or would you expect to pull the whole dishwasher out from under the work surface and roll it onto it’s side?
    Thanks again, in advance.
    Eddie
