October 26, 2009 at 3:37 pm in reply to: bosch SGS45E08GB/56 not draining, drain pump sounds “cl #300207
yeti-dj
ParticipantRe: bosch SGS45E08GB/56 not draining, drain pump sounds &
hello, the new problem is now the water in the machine is cold throughout the whole wash cycle?
Was also having a look at the machine when its running and there is a motor connected onto the instant water heater but it seems to be doing nothing, not once did this motor turn?
Just bought a new machine anyway but if i can fix this one i will
thanks for the help again…
October 23, 2009 at 4:01 pm in reply to: bosch SGS45E08GB/56 not draining, drain pump sounds “cl #300205yeti-dj
have now got it starting a wash cycle but its still hanging and have also noticed that the water inside the machine is cold. Think its time for the bin for my dishwasher!!!!
October 23, 2009 at 3:33 pm in reply to: bosch SGS45E08GB/56 not draining, drain pump sounds “cl #300204yeti-dj
ParticipantRe: bosch SGS45E08GB/56 not draining, drain pump?
hello, i have taken apart the pressure chamber apart and all its hoses. Every part looked like new and there was no gunk in it at all or any blockages. I rebuild the machine and tried it.
When i start a program the machine fills as normal until the flood switch is activated and then tries to drain, you can see water being pumped up the tubing on the side of the machine but it seems to be struggling to do this, it will sit trying to drain for a good while before eventually managing it and then it just fills again until the switch trips and it all happens again, the pump that drains it doesnt sound healthy at all….
I tried emptying the sump with a glass and once i did this the machine started the washing cycle until it reached a point then stuck there,probably when it needed to drain again im guessing?
Have tried all programs and each one is the same..
Any other ideas as to the problem???
October 22, 2009 at 8:35 pm in reply to: bosch SGS45E08GB/56 not draining, drain pump sounds “cl #300203yeti-dj
found the little rubber valve just next to the pump fins, removed this and i can now blow through the hose no bother so no blockages in the line.
job tomorrow is strip down the pressure chambert you have suggested and see if that helps..
thanks for the help and will let you know how i get on tomorrow night
October 22, 2009 at 8:10 pm in reply to: bosch SGS45E08GB/56 not draining, drain pump sounds “cl #300201yeti-dj
ok, i have taken off the LHS panel and removed the long length of hose so there is less for it to pump round, if you start the machine up it tries to empty the sump but the water only gets about half way up the plastic pipework that is on the side of the machine suggesting its not capable of pumping enough.
Should you be able to blow through the pipe work fairly easily as it isnt and takes a fair amount of puff, is there some kind of valve in the drain line?
thanks,,
