1937 GE flat top help needed
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum 1937 GE flat top help needed
Viewing 15 posts - 1 through 15 (of 35 total)
  • #81472
    karl brighton
    Hope to get some advice. Fridge had not been used for about 18 months. Had her running for about 3or 4 days. Working fine. Compressor switching on and off comfortably. Then seemed the compressor had been on a while. It was incredibly hot. Must have been going continuously for an hour. turning the thermostat down didn’t switch it off. I’m presuming the thermostat needs changing. Should I buy a ranco vx0. My main concern is the compressor getting so hot . Is this normal on these old compressors. Seems to sound very smooth when on. Cheers karl
    #416706
    Re: 1937 GE flat top help needed
    Possibly the thermostat but, hard to make a call on that without seeing the machine and you may well struggle badly with that.
    Thermostat could be a VT9 or a VXO, I really don’t know.
    I doubt many here have ever seen one, hence the lack of knowledge.
    1937 Wow!
    #416708
    Dependent on the fixings it may not be a standard swap over of the stat as some older refrigeration the fittings are different.
    Also it looks like you have a ice box in the centre and if the phile fastens onto that then its not a vt9 or vx0 it’ll need a ice box stat which is whirlpool kit 2 if I remember correctly.
    #416709
    karl brighton
    Hi. Yes that’s right. The stat sits in the top of the ice box. The phile wraps around the side of the ice box and fixes to the underside. The vx0 looks like it could be made to fit. But you don’t think this will work. I’ll order the one you recommend the voltage is 110v. Will these stats be ok, or do I need an american model. Cheers karl
    Ps mine is similar to the image. Much better condition. Slightly earlier. Wasn’t made with an ice box door.
    #416710
    Hi Karl
    You will need a thermostat suitable for a icebox fridge as if you fit a vx0 it will totally defrost that plate thus not allowing ice to be made
    #416711
    This one: http://shop.ukwhitegoods.co.uk/vxo-univ … thermostat
    karl brighton wrote:I’ll order the one you recommend the voltage is 110v. Will these stats be ok, or do I need an american model.
    The thermostat in this case is NOT voltage dependent , so it will work fine either on 110 or 240v.
    #416713
    karl brighton
    Cheers guys, this is really helping. Still not sure which thermostat i need. I should be able to adapt most to fit in. There’s plenty of space where it fixes in. Can email pics of fridge and location if it helps. Karl
    #416714
    Hi Karl
    Does it have a icebox that makes ice cubes ?
    #416715
    karl brighton
    Hi Bryan. Yes. It’s a small ribbed open metal box with 2 ice trays in there. There’s no flap on the front. The box ices up to cool the fridge. The thermostat sensor just fixes to the box. This also gets covered by frost. Cheers karl.
    #416716
    Hi Karl
    Then a VX0 will NOT work with your fridge.
    You need a stat that operates a fridge with a ice box and normally come with a push button for defrosting.
    #416717
    karl brighton
    Ice box image
    #416718
    karl brighton
    Hi Bryan
    http://shop.ukwhitegoods.co.uk/ranco-vp … ost-button
    Could try this one. Looks like it might fit? Really do appreciate the help on this forum. Cheers karl
    #416719
    Hi Karl
    Yes that should do it
