Home › Forums › Public Support Forums › Help And Support › Tumble Dryer Help Forum › 75/400 Creda tumble dryer (bought 1978)
- This topic has 47 replies, 3 voices, and was last updated 11 years, 9 months ago by
frdcre.
July 3, 2014 at 2:43 pm #416059
frdcre
ParticipantRe: 75/400 Creda tumble dryer (bought 1978)
Thankyou Martin, I’m preparing for the belt arrival– not here yet. This website’s shop advised POL08 was the right one — we shall see! I’ll report back
July 3, 2014 at 3:59 pm #416060iadom
ModeratorRe: 75/400 Creda tumble dryer (bought 1978)
I suspect that POL 08 will be too big, I think Martin is much nearer the mark with a POL 03.
A picture of the belt orientation for you.
July 3, 2014 at 4:07 pm #416061Martin
It’s an old bugger, as are we, but from my database (which I refer to occasionally) I fitted a POL03 to the last TD400 I saw in 1998.
July 3, 2014 at 4:09 pm #416062frdcre
Thanks iadom, as I said this website’s shop said to get the POL 08. If it is wrong I SHALL EXCHANGE IT FOR THE 03, as Martin hs now suggested I APPRECIATE THE EXPLODED VIEW. REGARDS
July 7, 2014 at 2:22 pm #416063frdcre
OK Martin belt arrived today. I’ve undone the nuts holding the cross struts to the front casing. There are 3 more nuts at the bottom of the front casing — do I have to remove them to get the front casing eased away from the drum? Simple it aint!
July 7, 2014 at 2:34 pm #416064Martin
Only undo the cross struts at the top. Do not undo the bottom!
Ease the drum away at the top sufficient to poke the belt through the small gap and fiddle it around the drum. Reattach the struts and ensure the drum rotates freely on the front tub support bearers before fitting belt on motor.
July 7, 2014 at 4:06 pm #416065frdcre
Thankyou Martin. Got some way but cannot seem to reveal the small gap at the bottom, and now seem to be bending the front panel out of shape! Is there any sense loosening the bottom screws a bit — or undoing the door springs?
July 7, 2014 at 4:22 pm #416066Martin
Door springs?……blimey no. As long as you can ease the drum out of the top of the front support then sufficient gap can be achieved to rotate the belt around the drum. No great physical force required, certainly not enough to bend the front panel because you will be in trouble if you do!
July 7, 2014 at 6:32 pm #416067iadom
Thinking back, some of these old stagers had a rod from back to front on either side secured with a small nut, has this got them?
July 7, 2014 at 7:15 pm #416068Martin
Participant75/400 Creda tumble dryer (bought 1978)
I referred to them earlier as “cross struts” 😉
July 8, 2014 at 8:29 am #416069frdcre
Yes iadom, I’ve got them both undone, and we (my wife and I) are about to try Martin’s latest advice, namely to slide the belt round the still closed part of the drum opening. It is a tight fit even with the gap opened at the top
July 8, 2014 at 1:40 pm #416070frdcre
Well we’ve got the belt past the two side bits of the front drum support — but the bottom bit is impossibly tight. Any ideas? (My wife — who wanted a new dryer — said no man could have fitted a new belt to this model — the design is too complicated, she says!!)
July 8, 2014 at 5:00 pm #416071frdcre
A few hours later…having taken off the back, and unscrewed the tiny nuts retaining the wire stay at mid height, THAT did the trick!But as you both rightly suggested this belt is TOO LONG! So I shall order POL 03 but now I know how to! Thanks for all the help
July 8, 2014 at 5:26 pm #416072iadom
Martin referred to the ‘cross struts at the top’. You eventually found the ‘rods’ much lower down that I was talking about. ;). I’m sure the correct belt will have it running for many years. 🙂
July 8, 2014 at 6:15 pm #416073Martin
Bugger….wrong belt eh? 😉
