advice on removing cap on drain pump???
Home Forums Public Support Forums Help And Support Washing Machine Help Forum advice on removing cap on drain pump???
Viewing 10 posts - 31 through 40 (of 40 total)
  • #388508
    DrDill
    Re: advice on removing cap on drain pump???
    Get an engineer out to repair it before you end up down the hospital with yourself being repaired by them.
    Sent from my iPhone
    http://www.kitchenkitsw.com
    #388509
    humourbash wrote:I like to learn and understand how to read voltage.
    This guys humour has taken a bash. :rolls:
    #388510
    But there’s the rub Martin, voltage has very little to do with resistance, insulation or continuity testing . 🙁
    #388511
    It will be if that guy finds himself connected in series with the darn machine. Joking aside his antics are getting dangerous….! I’m out of here! :rolls:
    #388512
    humourbash
    U all are shameful! I’m a good person who wants to learn to repair summat. Dont mean u make fun of those who wants to learn and to learn is getting advices. You might act like a know it all. No one’s perfect. Like you all seem to think that.
    GROW UP!
    #388513
    DrDill
    Your response demonstrates why we are right to warn you to proceed no further, i take my hat off to you for wanting to learn about electrical testing, however this forum is not the place to learn this, i suggest you enroll on an electrical course and then test meters and electrical appliances will be your playground, but not now.
    Seriously if we attempted to tell you how to do by words here and you get it wrong and electrocute yourself we will feel terrible and that simply cant happen.
    Now call the repair guy!
    Sent from my iPhone
    #388514
    humourbash
    Why should i call the repair man? All i want to know is narrow down the issue in why it carries on washing on any programme at 1 minute left. It keeps washing. It dont spin so i cancel the wash, switch to spin. It drains no problem. Spins no problem, opens door no problem. So why is it playing up? Looked online, all points to drain pump but i solved that! What else??
    Electrode myself? How can i with testers that have plastic handle. I’m not gonna touch wires. I’m too sensible to do that! Pmsl
    #388515
    humourbash
    Where do u find heating bit that warms water for the wash?? So i can UMPLUG THE MAINS and check connection is in properly.
    #388516
    DrDill
    Yes thats right, you will be an electrode if you mess with electrics when you are quite clearly out your depth.
    You asked for advice on using a meter, we cant tell you that because of forum rules and the saftey of yourself.
    Sent from my iPhone
    #388517
    humourbash
    Found a problem. Heater element broken. New part ordered.
