advice on removing cap on drain pump???
Home Forums Public Support Forums Help And Support Washing Machine Help Forum advice on removing cap on drain pump???
Viewing 15 posts - 1 through 15 (of 40 total)
  • #73701
    humourbash
    ok. i am new on here but i am stuck… bought washing machine HOTPOINT WT741. the previous owner said it was playing up.
    i inspected everything. seems to be in order. went to get drain cap off but could not as there is damage. the bit you hold on to unscrew is broken. i have no way of removing it. nor do i know if there is a tool to help remove this cap??
    What should i do? i hope i get some advice soon as i think now the problems the previous owner had was related to the drain pump being faulty. i do not want to buy a new unit yet until i inspect the problem within the cap!!!
    Thanks for reading and hope someone came across the same issue and can advice 🙂
    ohh. forgot this… the previous owner stated those problems…
    1- couple of settings are temperamental
    2= sometimes has to be spun twice
    i am led to believe the settings wont function properly if the drain pump is not functioning as it should?? and for the spun twice means blockage in drain pump as well??
    #388479
    Re: advice on removing cap on drain pump???
    If the filter insert (cap) is broken then it has almost certainly been damaged due to foreign bodies getting into the pump. Coins, nails, hairgrips and all sorts of rubbish end up in there if the user just can’t be bothered to check pockets.
    You can buy new filters but you would need to remove the pump from underneath to allow you to open the pump up to get rid of the obstructions. Other than that fitting a new pump is an alternative course of action.
    Be sure to remove the mains plug before putting your hands inside.
    THIS is the pump filter kit, comes with three different filters to cover all varients.
    The complete pump and filter is HERE
    #388480
    humourbash
    Thanks so much, will remove pump and try to clear things inside to try remove filter and replace it with a new one.
    That filter kit directly fits what i have?
    Remove pump, do i look in inlet/outlet to remove anything causing blockage and something make cap unable to be removed? How do i get cap/filter removed?
    Step by step be ideal pls or video? Thanks
    #388481
    We don’t do step by step or videos, we assume you have a reasonable level of competence, If not then you should get someone who has to have a look.
    If you tilt the machine back against a wall or similar you can drop the whole pump out of the bottom, just have a few towels handy and possibly someone to hold the machine steady for you.
    One of the filters in that kit will fit.
    #388482
    humourbash
    what do i do with other two that i am left with?
    #388483
    eBay 😀 Seriously I have no idea why Indesit supply them like this . ❓
    #388484
    humourbash
    how much each?
    #388485
    humourbash wrote:how much each?
    You can only buy them as a complete kit, the chances of anyone wanting the spares ones is remote, around 75{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} of the time it’s the same one that I find is needed. 😥
    I will make a starting bid of 1p for both of them. 😉
    #388486
    humourbash
    That what i meant lol, i found same product on ebay for £14.99 free p&p. Bought it now. Will remove pump tomorrow to try and take filter out.
    I am capable of doing it myself, just need a guide on safe way to remove filter without breaking the pump itself. A good method. Showing u a picture of it now. Hopefully u can help again 🙂
    #388487
    humourbash
    http://img.tapatalk.com/d/13/01/23/7eqeruhy.jpg
    #388488
    Take the pump off complete as described above. Once you have removed the hoses you should be able to get the obstructions out from the side of the pump.
    #388489
    humourbash
    Tapatalk is messed up!!! I like forumrunner better!!!
    Facebook add on is messing up the forum!!! I recommend forum admin to sack facebook app addon and add forumrunner!!!
    #388490
    Believe me, I have vented my spleen about the problems with Facebook, it’s a real PITA and no mistake. It makes the forum on Internet Explorer virtually unusable at times.I have to resort to my iPad or use Chrome on my PC to save me punching the screen. :rolls:
    PS, your picture was fine on Tapatalk.
    #388491
    humourbash
    On tapatalk trying to post, i keep getting this blasted message saying need proper host file starting with http crap! Lol
    #388492
    humourbash
    iadom wrote:Take the pump off complete as described above. Once you have removed the hoses you should be able to get the obstructions out from the side of the pump.
    thanks 🙂 so removing the filter while damaged on the outside, any trick on taking cap off??
