AEG OKO_Lavamat 6100 digitronic
Home Forums Public Support Forums Help And Support Washing Machine Help Forum AEG OKO_Lavamat 6100 digitronic
Viewing 15 posts - 1 through 15 (of 25 total)
  • #98213
    AEGowner
    E-Nr.605.648 372 F-Nr.094295696
    Hi, my trusty old AEG OKO_Lavamat 6100 digitronic washing machine was working fine until this morning when I noticed it wasn’t spinning properly – it did still spin but only for a few seconds at a time when it should have spun for several minutes, and the washing came out fairly wet. Other than that it goes through the programmes properly. Could the bearings have failed or might the carbon brushes be the problem? They needed replacing four years ago, but the drum didn’t spin at all then. Could anyone offer a suggestion as to what the problem might be and whether it is worth repairing please? Many thanks 🙂
    #471384
    have you tried it more than once as it could just be an unbalanced load
    AEGowner
    I tried putting it on empty. It went through the complete programme, but only spun for a few seconds at each stage.
    #471386
    we are looking at a machine built 1994
    if bearings had failed it would still spin but make lots of noise
    you can check carbons but it may not be that
    more likely a problem in the electronic control. Had a similar problem on old zanussi machine,which are now part of the same company, where the power supply to the electronics failed through age.The first sign of problems was an inability to spin. As it was gaining speed it would just slow down again and run slowly for a bit then try again. This repeated till the end of the programme
    to determine if yours maybe the same i would need to see some clear pics of the components on the pcb
    AEGowner
    What is the pcb?
    It does sound rather “tinny” when it spins.
    #471388
    printed circuit board
    in your case its the motor control board as the timer is mechanical
    noise when spinning can be the drum or motor bearings. of its the motor a small amount of wd40 in the correct place helps a lot
    AEGowner
    How can I take pics of that?
    #471390
    you need to take the lid off the machine
    find the board wihich is probably on the rear of the timer
    take some clear pic
    host them on another site like google pics
    then post public link so i can see them
    if it was a newer machine i could probably find the pics i need, now i did work on a few of these but cant rememer enough of what it looks like to be helpful. also since AEG was taken over there is no service info just part lists and breakdowns
    your should look like this
    https://kinseher-shop.de/Waschmaschine/Elektronik-Drehzahl-Drehzahlelektronik/Leistungelektronik-Waschmaschine-899645430705-AEG-Electrolux.html
    just need a clearer pic of the circuit components
    #471391
    AEGowner
    Thanks very much. It is too dark to see properly now, so I’ll do it first thing tomorrow morning.
    #471392
    what you could try is taking the board off and put it back, then try it again
    lost track of how many times bad connections cause problems and it has been on around 25 years
    AEGowner
    Okay, I’ll try that. Thanks for your help 🙂
    #471394
    AEGowner
    There were only two visible screws at the back holding the top on the machine. I undid them and although the top could be lifted up half a centimetre at the back, no matter what I did it wouldn’t come off. Is there a trick to removing it?
    #471395
    AEGowner
    Ignore that, have managed to remove the top now!
    #471396
    AEGowner
    Now the drum is not moving at all, it is completely stuck with no give at all. The machine still fills and empties though.
    I have had problems attaching a pic of inside the top, but I don’t think it showed much anyway.
    #471397
    AEGowner
