Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › BEKO D533 – Main oven not working
- This topic has 29 replies, 14 voices, and was last updated 16 years, 1 month ago by
mclmsn.
March 9, 2010 at 10:14 pm #53117
mclmsn
ParticipantI have a BEKO D533 which has developed a fault (typically 1 month after the guarantee expired) what has happend is that the main oven no longer works, there is no light and the fan does not move. The hob works but the light indicating it is on no longer comes on and the seperate grill still works.
Anyone have any ideas as to what might be wrong
March 10, 2010 at 12:32 am #314465Penguin45
ParticipantRe: BEKO D533 – Main oven not working
If the oven won’t do anything, there is probably a fault with the selector switch/thermostat unit in th econtrol panel. Top deck off to find out.
Power off first.
March 13, 2010 at 6:53 pm #314466TheSpinDoctor
mclmsn wrote:I have a BEKO D533 which has developed a fault (typically 1 month after the guarantee expired)
Hi.
Just a thought. Might be worthwhile contacting Beko to see if they will cover it as I have has experience of them doing so on appliances just out of warranty. Depends on circumstances but if you don’t ask, you don’t get.
April 1, 2010 at 5:02 pm #314467lozza69er
I can’t believe i am having exactly the same problem as you. Cooker went out the other night, i have the same model oven.
Did you find out what the problem was?
April 2, 2010 at 2:41 pm #314468lozza69er
Can someone help me with this problem, really need to get this fixed soon.
Took the back off today to have a look around and test a few things with the multimeter.
Tested continuity on the above (red) seems ok.
Tested continuity on the above (white lower), no continuity and the white cable had turned a little brown.
Would you think that this is the problem with my cooker?
Any help is much appreciated.
April 2, 2010 at 8:15 pm #314469TheSpinDoctor
If it is open circuit then yes that is a problem.
April 3, 2010 at 11:24 am #314470lozza69er
Thanks. Replaced and oven is now working fine.
February 1, 2011 at 9:11 pm #314471BleachedEgo
Hi. Really sorry to drag up an old thread, but whilst searching for an issue I have with my cooker Google brought me directly to this thread, as I am having the exact same issues as lozza69er and the OP, on the same make and model. I was wondering whether anyone knew what the item that lozza69er replaced was? I’m guessing that it was some kind of internal thermal fuse, but wanted to make sure.
Seeing that lozza69er has only posted the 3 posts above, it’s unlikely that he/she is an active user, but maybe one of you other guys has an idea.
Thanks in advance.
February 1, 2011 at 9:24 pm #314472kwatt
KeymasterFebruary 1, 2011 at 9:57 pm #314473BleachedEgo
kwatt wrote:It was probably this that was the problem.
Thanks kwatt. I’ve had the rear of the cooker off and thought it may have been one of these (there seems to be 2. One leading to 2 red wires and the other to 2 whites). Considering how cheap they are it’s well worth a punt just to eliminate it from the problem.
Thanks again.
February 3, 2011 at 8:58 pm #314474BleachedEgo
Just thought I’d post back to say thanks for your help kwatt. Item arrived today, fitted in just a few minutes and oven now works perfectly.
For anyone else who comes across this thread with the same issues:
1) Order the part in the kwatts link above
2) Turn off power source and disconnect cables from rear of cooker.
3) Remove rear panel with phillips head screwdriver
4) Locate connection on right hand side, mid way down the unit (two white wires leading to the part identical to the one you’ve purchased)
5) Unscrew the old thermostat and remove wires one connector at a time, making sure you connect them the exact way they come off.
6) Attach new thermostat. Reattach rear.
7) Screw wires back in, making sure the copper links are attached soundly.
8.) Turn on plug and oven
9) ProfitMay 16, 2011 at 10:32 am #314475Mykee
My problem is slightly different. The oven fan and light are OK, I just have no heat. I have removed the back and can see the two thermal fuses on the right-hand side, the upper with red wire and the lower with white wire. I don’t quite understand how to replace the fuse with the thermostat, if this is what is required in my case. Do I have to cut out the fuse and then attach spade connectors so that it will attach to the thermostat?
Mike O.
May 18, 2011 at 5:54 pm #314476Washman
If the fan and light are working the element has failed.
replace element.Washman
May 18, 2011 at 6:49 pm #314477blokes
Sounds like fan oven element to me.
Model no???
Steve
May 19, 2011 at 2:30 am #314478gandh1
NB to all beko owners attempting self-fixes = always be weary of the concrete weights bolted to back panels of these, very nearly broke a finger when putting the back panel of a beko back on, and the screw jumped back out.
