Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › BEKO no go!
- This topic has 21 replies, 6 voices, and was last updated 14 years, 2 months ago by
madrat.
January 15, 2012 at 7:31 pm #67386
madrat
ParticipantHi,
I have a BEKO WMA 642 W that has developed a fault tonight, can anyone possiblyly point me in the correct direction as to what is wrong.
When you start it on a wash program it takes in water and then dose nothing, I have tried it on rince and it dose the same, Tried it on spin and after the initial drain out nothing. If I leave it in spin it tries to start again after a minuets but again after draining nothing. The drum and motor are free to turn by hand and the pump in not blocked.
Any idea’s
January 15, 2012 at 7:38 pm #367300shaun67
ParticipantRe: BEKO no go!
Did it spin at all when you tried it ?
I would look at the brushes ? ..plug out if you investigate..
January 15, 2012 at 7:39 pm #367301bazza500
Brushes?
January 15, 2012 at 7:40 pm #367302QUICK FIX
carbon brushes in the motor
January 15, 2012 at 7:41 pm #367303madrat
No drum didnt move at all.
I tried moving it by hand when I started the program but it still wouldnt go.
January 15, 2012 at 7:42 pm #367304shaun67
Check the brushes as stated not dear at all to replace ..plug out though first..
January 15, 2012 at 7:46 pm #367305madrat
Ok I’m off to tip the machine over, back soon
Thanks :penguins:
January 15, 2012 at 8:01 pm #367306bazza500
The last person I knew of who did that lost 3 fingers. :eeek:
January 15, 2012 at 8:10 pm #367307madrat
😳 I know it’s not a good idea but the last machine that had the brushes go when you did this the drum tried to move ant there were lots of sparks to confirm the problem, but nothing this time.
Anyway I have the brushes and yes they are worn down to the limit of travel, and 1 more than the other. They are available on the part bit for £15.64. :tup: Could someone please confirm for me I have the correct ones, part number 371202410. Nice to see things held in by the good old Philips screw and not a torxs bit for a change. 😀
By the way what do I clean the contact on the motor with, I can’t remember.
January 15, 2012 at 8:23 pm #367308bazza500
Yes, they are the correct ones for your machine.
January 15, 2012 at 8:26 pm #367309madrat
Great thanks guys.
Just found a pair on Ebay for £5.90 with free postage Not genuine BEKO but who cares at that price. 😆
January 15, 2012 at 8:46 pm #367310bazza500
I would watch with the non gen Beko brushes. I stopped using them as they were causing excessive arcing and blowing the motor toc’s.
January 15, 2012 at 9:14 pm #367311madrat
I will keep an eye on them when fitted, thanks for the tip.
January 15, 2012 at 9:28 pm #367312bazza500
Compare them to your new ones before you fit them. Paying particular attention to the slope on the face of the brush. Some of the copies the slope is too much and causes only the tip of the brush to contact the motor causing overheating. This then results in the motor needing replaced.
January 15, 2012 at 9:32 pm #367313madrat
will do thanks.
What do I clean the motor contact with?
