BEKO no go!
Viewing 15 posts - 1 through 15 (of 22 total)
  • #67386
    madrat
    I have a BEKO WMA 642 W that has developed a fault tonight, can anyone possiblyly point me in the correct direction as to what is wrong.
    When you start it on a wash program it takes in water and then dose nothing, I have tried it on rince and it dose the same, Tried it on spin and after the initial drain out nothing. If I leave it in spin it tries to start again after a minuets but again after draining nothing. The drum and motor are free to turn by hand and the pump in not blocked.
    Any idea’s
    #367300
    shaun67
    Re: BEKO no go!
    Did it spin at all when you tried it ?
    I would look at the brushes ? ..plug out if you investigate..
    #367301
    bazza500
    Re: BEKO no go!
    Brushes?
    #367302
    QUICK FIX
    Re: BEKO no go!
    carbon brushes in the motor
    #367303
    madrat
    Re: BEKO no go!
    No drum didnt move at all.
    I tried moving it by hand when I started the program but it still wouldnt go.
    #367304
    shaun67
    Re: BEKO no go!
    Check the brushes as stated not dear at all to replace ..plug out though first..
    #367305
    madrat
    Re: BEKO no go!
    Ok I’m off to tip the machine over, back soon
    Thanks :penguins:
    #367306
    bazza500
    Re: BEKO no go!
    The last person I knew of who did that lost 3 fingers. :eeek:
    #367307
    madrat
    Re: BEKO no go!
    😳 I know it’s not a good idea but the last machine that had the brushes go when you did this the drum tried to move ant there were lots of sparks to confirm the problem, but nothing this time.
    Anyway I have the brushes and yes they are worn down to the limit of travel, and 1 more than the other. They are available on the part bit for £15.64. :tup: Could someone please confirm for me I have the correct ones, part number 371202410. Nice to see things held in by the good old Philips screw and not a torxs bit for a change. 😀
    By the way what do I clean the contact on the motor with, I can’t remember.
    #367308
    bazza500
    Re: BEKO no go!
    Yes, they are the correct ones for your machine.
    #367309
    madrat
    Re: BEKO no go!
    Great thanks guys.
    Just found a pair on Ebay for £5.90 with free postage Not genuine BEKO but who cares at that price. 😆
    #367310
    bazza500
    Re: BEKO no go!
    I would watch with the non gen Beko brushes. I stopped using them as they were causing excessive arcing and blowing the motor toc’s.
    #367311
    madrat
    Re: BEKO no go!
    I will keep an eye on them when fitted, thanks for the tip.
    #367312
    bazza500
    Re: BEKO no go!
    Compare them to your new ones before you fit them. Paying particular attention to the slope on the face of the brush. Some of the copies the slope is too much and causes only the tip of the brush to contact the motor causing overheating. This then results in the motor needing replaced.
    #367313
    madrat
    Re: BEKO no go!
    will do thanks.
    What do I clean the motor contact with?
