Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › BOSCH CLASSIXX 1200 inactive!
- This topic has 20 replies, 3 voices, and was last updated 12 years, 2 months ago by
Jimleach.
February 6, 2014 at 1:31 pm #79402
Jimleach
ParticipantHi everyone.
My bosch classixx stopped turning the drum yesterday, I figured it was probably motor brushes. I bought new ones and replaced this morning. However now it won’t turn on, no lights nothing. I have checked the fuse and am at a bit if a loss. Any help would be greatful.
Kind regards
Jim
February 6, 2014 at 2:20 pm #409041Jimleach
ParticipantRe: BOSCH CLASSIXX 1200 inactive!
Is there some sort of safety switch on the top panel that could of malfunctioned? Can’t see anything.
February 6, 2014 at 2:31 pm #409042Andy jones
Only way to be certain in to make sure you have power actually to the mains terminal. This can only be done with a meter.
February 6, 2014 at 5:27 pm #409043Jimleach
Hi Andy there is 240v at the terminals where the mains flex connects
February 6, 2014 at 5:33 pm #409044Andy jones
Sounds like the board is suspect
February 6, 2014 at 5:40 pm #409045Jimleach
Balls, can’t understand why it would go after replacing brushes, just coincidence? Or could I have done something?
February 6, 2014 at 7:01 pm #409046Martin
If the model number begins WFO????? Then the PCB could well be a goner.
February 6, 2014 at 8:22 pm #409047Jimleach
It’s WFL
February 6, 2014 at 8:26 pm #409048Jimleach
WFL 2463GB to be precise 🙂
February 7, 2014 at 7:05 am #409049Jimleach
Am I best getting a pro out or buying a new machine?
February 7, 2014 at 8:15 am #409050Martin
Jimleach wrote:Am I best getting a pro out or buying a new machine?
You work it out, a new control PCB fitted would set you back up to £170. A replacement machine of same quality £375.
February 7, 2014 at 8:55 am #409051Jimleach
No brainer then really. I suppose it’s just trying to work out if it could be anything goes simpler.
February 7, 2014 at 8:59 am #409052Martin
Jimleach wrote:No brainer then really. I suppose it’s just trying to work out if it could be anything goes simpler.
To answer that would be to unplug the machine then take out the PCB (photograph the connections before removing) and check the board for potential component damage or bad connections. 💡
February 8, 2014 at 3:27 pm #409053Jimleach
Ok circuit board removed…. This looks suspect, or is it just dirt? https://www.dropbox.com/sh/7584gosbf5xjw66/TvUtUDfsrH
February 8, 2014 at 3:34 pm #409054Martin
That’s just dirt/carbon dust and should clean off easily.
