BOSCH CLASSIXX 1200 inactive!
Home Forums Public Support Forums Help And Support Washing Machine Help Forum BOSCH CLASSIXX 1200 inactive!
Viewing 15 posts - 1 through 15 (of 21 total)
  • #79402
    Jimleach
    Hi everyone.
    My bosch classixx stopped turning the drum yesterday, I figured it was probably motor brushes. I bought new ones and replaced this morning. However now it won’t turn on, no lights nothing. I have checked the fuse and am at a bit if a loss. Any help would be greatful.
    Kind regards
    Jim
    #409041
    Jimleach
    Re: BOSCH CLASSIXX 1200 inactive!
    Is there some sort of safety switch on the top panel that could of malfunctioned? Can’t see anything.
    #409042
    Andy jones
    Only way to be certain in to make sure you have power actually to the mains terminal. This can only be done with a meter.
    #409043
    Jimleach
    Hi Andy there is 240v at the terminals where the mains flex connects
    #409044
    Andy jones
    Sounds like the board is suspect
    #409045
    Jimleach
    Balls, can’t understand why it would go after replacing brushes, just coincidence? Or could I have done something?
    #409046
    If the model number begins WFO????? Then the PCB could well be a goner.
    #409047
    Jimleach
    It’s WFL
    #409048
    Jimleach
    WFL 2463GB to be precise 🙂
    #409049
    Jimleach
    Am I best getting a pro out or buying a new machine?
    #409050
    Jimleach wrote:Am I best getting a pro out or buying a new machine?
    You work it out, a new control PCB fitted would set you back up to £170. A replacement machine of same quality £375.
    #409051
    Jimleach
    No brainer then really. I suppose it’s just trying to work out if it could be anything goes simpler.
    #409052
    Jimleach wrote:No brainer then really. I suppose it’s just trying to work out if it could be anything goes simpler.
    To answer that would be to unplug the machine then take out the PCB (photograph the connections before removing) and check the board for potential component damage or bad connections. 💡
    #409053
    Jimleach
    Ok circuit board removed…. This looks suspect, or is it just dirt? https://www.dropbox.com/sh/7584gosbf5xjw66/TvUtUDfsrH
    #409054
    That’s just dirt/carbon dust and should clean off easily.
