Bosch Classixx SGS53C12 Dishwasher
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Bosch Classixx SGS53C12 Dishwasher
Viewing 15 posts - 1 through 15 (of 26 total)
  • #75967
    Ajuga
    The cycle on this DW seems to last a very long time. I am unable to find anywhere how long each cycle should last. The last drying cycle seems to be going on for a much longer time than seems necessary. Can anyone give me an indication of timings please.
    #396789
    Re: Bosch Classixx SGS53C12 Dishwasher
    Sounds like it is not heating the water then?
    #396790
    Ajuga
    Not sure what you mean. Why would that affect the length of the cycle – everything is clean so don’t think that is the problem.
    #396791
    Ajuga wrote: everything is clean so don’t think that is the problem.
    So, does it heat then? After the cycle finishes are the crocks hot?
    #396792
    Ajuga
    Yes I am sure they are but will double check next time I turn it on. It takes much longer for a cycle than my last Bosch but yesterday it just seemed to be going on forever. Which is why I wondered if anyone could tell me how long a cycle is supposed to last. Thank you for your replies.
    #396793
    Longest cycle would be around 2 – 2.5hrs.
    #396794
    Ajuga
    I use the Eco 50 degree wash so that would be about 2 hrs? Maybe I am just impatient and comparing it to my old dishwasher which was much quicker. I will check it next time and come back if I am still worried. Thank you.
    #396795
    Ajuga
    I think it does have a problem. I turned it on this morning with a view to timing how long it took but it starts up but is not filling with water so not even starting the cycle now. What could be causing this?
    #396796
    Ajuga wrote:but is not filling with water
    Check the water inlet stop tap and inlet valve filter to ensure a water supply is getting to the machine and that the filter isn’t clogged, for starters.
    #396797
    Ajuga
    Thank you. Will check all that later. I have just found the reset button and that seems to have done the trick in getting it started and filling with water etc.It is now moving through the cycle. I hope it will continue to behave.
    #396798
    Ajuga
    Back to problems again – at the end of the cycle goes on and on sounding as if it is trying to drain.
    A question – when I took the filter out to clean it the well still had water in it – is this normal? I thought it was usually empty. Thanks for any tips.
    #396799
    Ajuga wrote:Back to problems again – at the end of the cycle goes on and on sounding as if it is trying to drain.
    Check the domed float switch behind the spay arm isn’t stuck.
    Ajuga wrote:A question – when I took the filter out to clean it the well still had water in it – is this normal? I thought it was usually empty.
    It’s a gravity fed pump and not a suction pump so a residual amount of water will always remain in the sump.
    #396800
    Ajuga
    Thank you for your reply. Have checked the domed float switch and I can lift it up so presume it is not sticking.
    #396801
    When the pump runs continually will it still run whilst opening the door?
    #396802
    Ajuga
    I will check that out.
