Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Bosch Classixx SGS53C12 Dishwasher
- This topic has 25 replies, 3 voices, and was last updated 12 years, 9 months ago by
Ajuga.
June 23, 2013 at 3:29 pm #75967
Ajuga
ParticipantThe cycle on this DW seems to last a very long time. I am unable to find anywhere how long each cycle should last. The last drying cycle seems to be going on for a much longer time than seems necessary. Can anyone give me an indication of timings please.
June 23, 2013 at 4:28 pm #396789Martin
ParticipantRe: Bosch Classixx SGS53C12 Dishwasher
Sounds like it is not heating the water then?
June 24, 2013 at 7:41 am #396790Ajuga
Not sure what you mean. Why would that affect the length of the cycle – everything is clean so don’t think that is the problem.
June 24, 2013 at 7:44 am #396791Martin
Ajuga wrote: everything is clean so don’t think that is the problem.
So, does it heat then? After the cycle finishes are the crocks hot?
June 24, 2013 at 8:18 am #396792Ajuga
Yes I am sure they are but will double check next time I turn it on. It takes much longer for a cycle than my last Bosch but yesterday it just seemed to be going on forever. Which is why I wondered if anyone could tell me how long a cycle is supposed to last. Thank you for your replies.
June 24, 2013 at 8:27 am #396793Martin
Longest cycle would be around 2 – 2.5hrs.
June 24, 2013 at 8:34 am #396794Ajuga
I use the Eco 50 degree wash so that would be about 2 hrs? Maybe I am just impatient and comparing it to my old dishwasher which was much quicker. I will check it next time and come back if I am still worried. Thank you.
June 25, 2013 at 9:44 am #396795Ajuga
I think it does have a problem. I turned it on this morning with a view to timing how long it took but it starts up but is not filling with water so not even starting the cycle now. What could be causing this?
June 25, 2013 at 11:23 am #396796Martin
Ajuga wrote:but is not filling with water
Check the water inlet stop tap and inlet valve filter to ensure a water supply is getting to the machine and that the filter isn’t clogged, for starters.
June 25, 2013 at 11:26 am #396797Ajuga
Thank you. Will check all that later. I have just found the reset button and that seems to have done the trick in getting it started and filling with water etc.It is now moving through the cycle. I hope it will continue to behave.
July 2, 2013 at 1:19 pm #396798Ajuga
Back to problems again – at the end of the cycle goes on and on sounding as if it is trying to drain.
A question – when I took the filter out to clean it the well still had water in it – is this normal? I thought it was usually empty. Thanks for any tips.
July 2, 2013 at 2:08 pm #396799Martin
Ajuga wrote:Back to problems again – at the end of the cycle goes on and on sounding as if it is trying to drain.
Check the domed float switch behind the spay arm isn’t stuck.
Ajuga wrote:A question – when I took the filter out to clean it the well still had water in it – is this normal? I thought it was usually empty.
It’s a gravity fed pump and not a suction pump so a residual amount of water will always remain in the sump.
July 2, 2013 at 4:31 pm #396800Ajuga
Thank you for your reply. Have checked the domed float switch and I can lift it up so presume it is not sticking.
July 2, 2013 at 5:02 pm #396801Martin
When the pump runs continually will it still run whilst opening the door?
July 2, 2013 at 5:09 pm #396802Ajuga
I will check that out.
