Bosch dishwasher not drying
Viewing 15 posts - 1 through 15 (of 17 total)
  • #78141
    AASWALES
    Hi I fitted a control board to this dishwasher a few months ago and all has been fine but the customer has called saying it is not drying the dishes properly , the dishes are warm so the heater is ok , it started intermittently but now does it every time , don’t have the model to hand but will be calling round on Monday so will update the post with model details ,
    Cheers alan
    #404622
    Re: Bosch dishwasher not drying
    Have you configured it as per the instruction leaflet?
    #404623
    AASWALES
    Hi I did follow the instruction to configure it but if I remember correctly they were not very clear and I did have some problems , can’t seem to find the sheet now do you know where I could download one ? Thanks alan
    #404624
    OK Alan….next, and most obvious, question …what is the Enr number of this machine?
    #404625
    AASWALES
    Will let you know Monday , thanks Martin
    #404626
    nomadPaul
    I’d first be asking the customer if they’re using the quick wash cycle…..which doesn’t have a drying cycle .
    #404627
    AASWALES
    Hi Paul , the customer has tried 3 different programmes all with the Same result but I have spoken to her today and she said that it seems to be sticking on 1 min remaining ?
    #404628
    nomadPaul
    In that case , look at the top of the forum stickies and you’ll see a post about Bosch/Neff/Siemens dishwashers with 1min left ‘Syndrome’. Everything you need to know should be in there. Its normally a blocked pressure chamber/fill hose problem.
    #404629
    AASWALES
    Just had a read of that sticky , gives me something to look into tomorrow cheers
    #404630
    AASWALES
    Model details are sgs55c02gb/01 ,
    Tested today and water comes in ok and drains ok heater is working ,, customer said she opened the door without turning off when I was stuck on 1 min and when she shut the door timer went to 23 mins , unfortunately she canceled the wash and didn’t not let it run but all was wet inside
    #404631
    For what it’s worth, I reckon dodgy heater relay (dry joint) or connector block loose on PCB (even though the PCB isn’t that old).
    #404632
    AASWALES
    Ok thanks for your thoughts I’ll check those and post back , cheers
    #404633
    AASWALES
    Hi been out the this dishwasher again today and the board was programmed to c6 and not c3 as I had set it when I fitted it ? Anyway reprogrammed it so fingers crossed it should work but I spoke to the customer today and she said she used the quick wash 28 mins and the machine finished and dried perfectly not sticking on 1 min at all ?
    I read somewhere that there was 2 dry settings on the board that could be changed but cannot find the site I read it on , does anyone know the procedure to change this setting ? Cheers alan
    #404634
    As nomadpaul said earlier there is NO drying function on the Quick Wash cycle (or Pre-rinse for that matter) and that model does not have the option of ‘Intensive Drying’.
    #404635
    AASWALES
    Hi update on this bloody dishwasher 🙁
    Customer has tried it on all progs and if she opens and closes the door before the timer says it’s finished the display changes from say 8 or 2 mins whatever it was on to 27 mins and dries perfectly every time ?? It always goes back to 27 mins and finished perfectly ??
    Any ideas ?
    Thanks alan
