Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Bosch HBC84K550B/04 Combi’ Oven/Microwave
- This topic has 23 replies, 4 voices, and was last updated 4 years, 5 months ago by
jontymox.
October 20, 2021 at 8:13 am #100151
jontymox
ParticipantGood morning all,
I’ve brought the above oven back to my workshop, as it has a fault with the microwave.
After around 5 seconds on any microwave setting, the unit stops/aborts.
As I do very few microwaves, I’m unsure where to focus my inspection/tests for this fault, and would welcome some assistance.
Thanks in advance,jonty
October 20, 2021 at 8:19 am #479477SWERV
ParticipantI would be having a close look at the Magnetron and inverter/power module.
Check the Magnetron for an earth fault, also remove it and check that the magnets are intact and check the condition of the antenna. If it all appears fine, then the likely cause will be the Inverter.Merv
October 20, 2021 at 8:40 am #479478jontymox
ParticipantThanks for your quick reply Merv,
Will have chance to have a look this p.m.
I’m aware about the extremely high voltage in the magnetron etc, and wonder if I can discharge it, or if a special tool is required?
jontyOctober 20, 2021 at 8:58 am #479479electrofix
Moderatorits will be a mag or inverter
first job
if you look at a mag and look at the connection box, there are normally air holes in ittake the cover off, disconnect the lamp and in a dim lit room operate it on full power microwave
look through the holes and your looking for a glow which is caused by the heater
if you get the then chances are its just the mag and since these units use panasonic bit it not too pricy
as for discharge, yes you need to get into the habit of doing it all the time. you just need to touch one of the mag leads to the metal chassis. you can use long well insulated screw drivers ( with a bare steel blade) hold it on the chassis and touch either of the leads. as an extra as you remove the lead touch the mag casing
voltages involved are 5000v DC plus a low voltage high current heater which is probably 6 to 12 v or so
October 20, 2021 at 9:43 am #479480adv
Participantit was the capacitor that held the high voltage. on most i done a while back .
October 20, 2021 at 9:46 am #479481electrofix
Moderatoradv wrote:it was the capacitor that held the high voltage. on most i done a while back .
its always the cap but bosch mocrowaves use an inverter board so its not like the standard transformer diode and cap situation
October 20, 2021 at 6:02 pm #479482adv
Participantits got to be the inverter board or mag .am sure my brother had one like this , he changed the inverter board still same . then changed magetron. still same .. so was about to give up . then tried a gunuine magnetron it worked . the cheaper one from connect was not good enough quality ..amen
October 20, 2021 at 6:06 pm #479483electrofix
Moderatorqualtex stock the gen panasonic mag 2M236M42E2
used that a lot with no problems
DaveOctober 21, 2021 at 6:08 pm #479484jontymox
ParticipantLooks like a faulty magnetron.
However, Qualtex only show the original Bosch 642266 item, with no alternative.
Wondering if the Panasonic 2M236M42E2 is compatible, as suggested, as it is also a good price and in stock at Qualtex?
jontyOctober 21, 2021 at 7:08 pm #479485electrofix
Moderatorwhat the number on the mag ?
October 22, 2021 at 9:21 am #479486jontymox
ParticipantJust to confirm the number on the unit is 2M261-M32 which is in stock at Connect.
jontyOctober 22, 2021 at 10:14 am #479487electrofix
ModeratorAswo also have stock at £37 plus vat and carriage
connect to me are showing £51 pls vat and carriageor you could contact
DaveOctober 27, 2021 at 10:18 am #479488jontymox
ParticipantAlas, I’ve renewed the magnetron, and the fault remains…
There is clear cracking/damage to the magnets in the above, so I wonder if the mag’ has also damaged the inverter/power module, which looks ok visually?
However, Bosch ask nearly £200.00 for the above, which I’m sure can also be obtained cheaper.
So, I’ll contact customer and explain…
jontyOctober 27, 2021 at 11:56 am #479489electrofix
Moderatoryes they can be got a lot cheaper
try contacting
https://www.ebay.co.uk/str/theonestopsatshop?_trksid=p2047675.l2563had a few of this seller
October 28, 2021 at 1:33 pm #479490jontymox
ParticipantWell, my customer asked me to continue and I managed to quickly obtain a inverter/power module, which I have just fitted.
Alas, the fault remains…
I can hear a relay on the module-relay board clicking on and off as expected, and now wonder if that is the cause, although Bosch would like £100.00 for this?
jonty -
