Bosch HBC84K550B/04 Combi’ Oven/Microwave
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch HBC84K550B/04 Combi’ Oven/Microwave
Viewing 9 posts - 16 through 24 (of 24 total)
  • #479491
    sometimes there is a fuse on the main board
    another thing you can check. there is a mains supply to the inverter board. its a 2 pin connector. disconnect and see if you get 240v when you activate the microwave
    there are only 3 connections to the inverter. mains in, 5000v dc plus heater voltage out and a small data cable
    was the inverter new ?
    SWERV
    It is definitely worth checking the fuse on the board. If the inverter has failed, that has most likely blown the fuse.
    #479493
    adv
    bet you wished you had walked away 🙁
    #479494
    jontymox
    Success!
    Fuse in Module had blown – Fitted a 10 Amp fuse to test, and all well.
    Markings on original ESKA fuse M 8/250 G and I wonder if 8 refers to 8 Amps?
    Thanks again to all feedback, and help.
    jonty
    #479495
    according to connect its 10A
    adv
    jontymox wrote:Success!
    jonty
    very good so was it just that all along ?:o
    #479497
    jontymox
    Well, without refitting the faulty inverter/power module, I can only surmise that it blew said fuse when it failed….
    #479498
    will tell you now the inverter is dud
    if the mag only fails it does not blow the fuse
    adv
    electrofix wrote:will tell you now the inverter is dud
    you heard it from the top 😉
