Bosch HBC84K550B/04 Combi’ Oven/Microwave
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch HBC84K550B/04 Combi’ Oven/Microwave
Viewing 15 posts - 1 through 15 (of 24 total)
  • #100151
    jontymox
    Good morning all,
    I’ve brought the above oven back to my workshop, as it has a fault with the microwave.
    After around 5 seconds on any microwave setting, the unit stops/aborts.
    As I do very few microwaves, I’m unsure where to focus my inspection/tests for this fault, and would welcome some assistance.
    Thanks in advance,
    jonty
    #479477
    SWERV
    I would be having a close look at the Magnetron and inverter/power module.
    Check the Magnetron for an earth fault, also remove it and check that the magnets are intact and check the condition of the antenna. If it all appears fine, then the likely cause will be the Inverter.
    Merv
    #479478
    jontymox
    Thanks for your quick reply Merv,
    Will have chance to have a look this p.m.
    I’m aware about the extremely high voltage in the magnetron etc, and wonder if I can discharge it, or if a special tool is required?
    jonty
    #479479
    its will be a mag or inverter
    first job
    if you look at a mag and look at the connection box, there are normally air holes in it
    take the cover off, disconnect the lamp and in a dim lit room operate it on full power microwave
    look through the holes and your looking for a glow which is caused by the heater
    if you get the then chances are its just the mag and since these units use panasonic bit it not too pricy
    as for discharge, yes you need to get into the habit of doing it all the time. you just need to touch one of the mag leads to the metal chassis. you can use long well insulated screw drivers ( with a bare steel blade) hold it on the chassis and touch either of the leads. as an extra as you remove the lead touch the mag casing
    voltages involved are 5000v DC plus a low voltage high current heater which is probably 6 to 12 v or so
    adv
    it was the capacitor that held the high voltage. on most i done a while back .
    #479481
    adv wrote:it was the capacitor that held the high voltage. on most i done a while back .
    its always the cap but bosch mocrowaves use an inverter board so its not like the standard transformer diode and cap situation
    adv
    its got to be the inverter board or mag .am sure my brother had one like this , he changed the inverter board still same . then changed magetron. still same .. so was about to give up . then tried a gunuine magnetron it worked . the cheaper one from connect was not good enough quality ..amen
    #479483
    qualtex stock the gen panasonic mag 2M236M42E2
    used that a lot with no problems
    jontymox
    Looks like a faulty magnetron.
    However, Qualtex only show the original Bosch 642266 item, with no alternative.
    Wondering if the Panasonic 2M236M42E2 is compatible, as suggested, as it is also a good price and in stock at Qualtex?
    jonty
    #479485
    what the number on the mag ?
    jontymox
    Just to confirm the number on the unit is 2M261-M32 which is in stock at Connect.
    jonty
    #479487
    Aswo also have stock at £37 plus vat and carriage
    connect to me are showing £51 pls vat and carriage
    or you could contact
    https://www.magsells.co.uk/
    jontymox
    Alas, I’ve renewed the magnetron, and the fault remains…
    There is clear cracking/damage to the magnets in the above, so I wonder if the mag’ has also damaged the inverter/power module, which looks ok visually?
    However, Bosch ask nearly £200.00 for the above, which I’m sure can also be obtained cheaper.
    So, I’ll contact customer and explain…
    jonty
    #479489
    yes they can be got a lot cheaper
    try contacting
    https://www.ebay.co.uk/str/theonestopsatshop?_trksid=p2047675.l2563
    had a few of this seller
    jontymox
    Well, my customer asked me to continue and I managed to quickly obtain a inverter/power module, which I have just fitted.
    Alas, the fault remains…
    I can hear a relay on the module-relay board clicking on and off as expected, and now wonder if that is the cause, although Bosch would like £100.00 for this?
    jonty
