Bosch KGU3201GB E2 problem
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Bosch KGU3201GB E2 problem
  • This topic has 26 replies, 11 voices, and was last updated 21 years ago by TKE.
Viewing 15 posts - 1 through 15 (of 27 total)
  • #8794
    TKE
    My Bosch KGU3201GB fridge/freezer is displaying a flashing E2 on the fridge display. I have read various solutions to this problem on this forum but none are exactly the same wiring as in my fridge.
    There are two boards, one of which has the display/control switches and is connected to the other board via a 20-way ribbon cable. There are also 2 wires from the main on/off switch on the front panel. The main board plugs into 2 sockets and there are no other connections to any sensors etc. Can anyone tell me exactly which wires and which board needs modification?
    #130525
    sparkey
    Re: Bosch KGU3201GB E2 problem
    This fault code indicates a failed fridge evaporator, only cure is replacement of electronic control board in top of fridge (flat plug in one).
    sensor modifications do not work on this model
    Please post full Enr No. or refer to http://www.bsh.co.uk for price of board. is expensive πŸ˜₯ if you have any doubts click on the big red tool box to find an independent engineer in your area πŸ˜‰
    Regards
    Sparkey
    #130526
    BSH-MAN
    Did the fridge section freeze food just prior to the E2 fault?
    #130527
    TKE
    Fridge seemed to be working normally before the fault – although occasesionally it did go above +5. Freezer is working OK.
    Any further advice would be much appreciated.
    #130528
    BSH-MAN
    It’s important to know if this is a KGU3201GB/01 or a KGU3201GB/05.
    E2 fault is not the same for both revisions IIRC.
    #130529
    TKE
    How can I tell? The identification plate in the bottom left of the fridge is now illegible. Is there some other way of identifying it? Is there a difference in the control boards?
    #130530
    sparkey
    How can I tell?
    KGU3201GB/01 has operating panel inside front facia and flat power board that slots into top of appliance.
    KGU3201GB/05 has operating panel inside front facia and power board in compressor recess near lamp transformer
    Regards
    Sparkey
    #130531
    BSH-MAN
    Looks like 263782 module for you then. πŸ™‚
    #130532
    TKE
    Looks like I have the 01 version. Can you confirm that its the 263782 module I need. Any idea of cost.
    Does this mean that my current control board has blown components or is it a totally different board that is supplied to rectify the fault?
    #130533
    BSH-MAN
    Yes, yours is a /01 from your posts.
    E2 means the fridge evaporator sensor NTC is reading >45 or <-35C i.e. it’s knackered! (Or wet)
    The function of this sensor is to control the defrost of the fridge section evaporator (back wall).
    The sensor is buried under the insulation and it’s not a good idea to try and replace it.
    A solution is to replace the large plug in module with a service module 263782 as this ignores the sensor by using a set time to allow the evaporator to defrost.
    The bad news is that it retails at Β£96 + VAT
    πŸ˜₯
    #130534
    have the /01 fridge/ freezer here as well with the same E2 fault ie freezer OK but fridge no go
    Any idea where i can buy the service module 263782 from please?
    Cheers
    #130535
    Dave_Conway
    I can get one for you or you can order online here:
    https://portal.bsh-partner.com/portal(bD1lbiZjPTAwOQ==)/PORTALFRAME.HTM
    Click on “service” then “quickfinder” as you know the part number, then click on “shopping basket” and add it directly from there πŸ˜€
    #130536
    cheers for prompt reply Dave_Conway
    ufortunately link not working here :(,
    could you email it to sdeanjd@netscape.net
    much appreciated
    #130537
    Dave_Conway
    Ah, try this:
    http://www.bshappliancecare.com/Bosch/boschspares.html
    Then click on the “quickfinder” application link lower right πŸ˜‰
    #130538
    ok thanks
