broadband
Home Forums General Trade Forum broadband
Viewing 15 posts - 1 through 15 (of 22 total)
  • #13639
    tonyclifton
    Blocked
    anyone know better deal for broadband as been using bt business broadbband just got a bill for over £300 😯
    #155792
    Re: broadband
    I use Ntl for my broadband service, £24.99 per month for 2 meg, going up to 10 meg 😯 if I want it for £37.99 soon. Some areas do have problems with Ntl due to the difference in the quality of their networks, round here it was installed by Cable & Wireless so we have a good service.
    I also have a Zen dial up account as a back up. been with them over 9 years, top class support, Their broadband service is always at or near the top of the tree in any survey .
    http://www.zen.co.uk/
    #155793
    Re: broadband
    Have you ever checked that you actually get 2 meg? mine is supposed to be 1 meg but I’ve known it go as slow as 16 k, i.e. slower than a dial-up. BT were always good at ripping off businesses.
    #155794
    Re: broadband
    Phidom wrote:Have you ever checked that you actually get 2 meg? mine is supposed to be 1 meg
    Yep, run speed tests several times, cable works very well if the infrastructure is sound, and a 20 to 1 contention rate unlike ADSL which has a 50 to 1 rate in most cases.
    Here you go, a copy of a quick speed test done a second ago.
    Mon, 28 Nov 2005 17:27:04 UTC
    1st 128K took 547 ms = 239620 Bytes/sec = approx 1994 kbits/sec
    2nd 128K took 531 ms = 246840 Bytes/sec = approx 2054 kbits/sec
    3rd 128K took 531 ms = 246840 Bytes/sec = approx 2054 kbits/sec
    4th 128K took 532 ms = 246376 Bytes/sec = approx 2050 kbits/sec
    In fact that is fractionally over 2 meg 🙂
    #155795
    gegsy
    Re: broadband
    Try this link for an accurate gauge of speed http://www.btopenworld.com/speedtest
    Greg 😉
    It will download a file and look at kb/s
    ie – 100kb/s =1mb/sec
    I use BT 2mb home user – and it can vary from 1.3mb – 2.4mb sec.
    Its alll down to contention. Bt use 50:1 that means you could be at worst sharing your connection with 49 other users and if they all downloading would make it really slow.
    #155796
    Re: broadband
    What is the cost of your BT 2 meg service with 50:1 contention compared to my Ntl 20:1 at £24.99 ?
    #155797
    gegsy
    Re: broadband
    £22.99 but I cant get cable
    Re: broadband
    I’m confused by that BT speed test link:
    File download size Minimum download time expected @ 500kbit/s
    Small (5 Mbytes) 1 minute 45 seconds
    Medium (10 Mbytes) 3 minutes
    Large (15 Mbytes) 4 minutes 30 seconds
    Is 2 Meg Broadband 2 million bits per second, not 2 million bytes?
    #155799
    gegsy
    Re: broadband
    1mb – One million bytes (1,000,000 bytes or 1,048,576 bytes)
    #155801
    robdray
    Re: broadband
    Wanadoo are doing wireless broadband for 17.99 a month / 2 meg and that includes all off peak calls (7-7) … no probs so far … you get to put your pc anywhere in the house / shop …
    #155802
    Re: broadband
    So, if ISPs are quoting speeds in Mb, not MB then, by my calculations a 2Mb connection will allow data to transfer at 220KB/sec.
    #155803
    gegsy
    Re: broadband
    Phidom wrote:So, if ISPs are quoting speeds in Mb, not MB then, by my calculations a 2Mb connection will allow data to transfer at 220KB/sec.
    Thats the way I read it Phidom, 220kb/s app 2.2mb so very good connection speed.
    Neil7741
    Re: broadband
    Divide the Mb value by 8 to get the MB value
    i.e. A 1Mb (1024Kb) connection transfers at 128KB per second
    #155805
    Re: broadband
    Don’t bother with Tiscali for your Broadband, I just managed to get connected after trying since 6.30pm. I’ve been doing modem tests, line tests and god knows what else to try and sort it but I suppose they were just overloaded with surfers. :haier:
