Home › Forums › Public Support Forums › Buying Advice › Can I get a Non Sealed Tub Washing Machine Sub £500?
- This topic has 34 replies, 6 voices, and was last updated 10 years, 4 months ago by
rustyspoons.
December 9, 2015 at 1:41 pm #433358
rustyspoons
ParticipantRe: Can I get a Non Sealed Tub Washing Machine Sub £500?
Hi Don,
Yeah I know I can adjust the feet, which is what I have been doing, which is a RIGHT PAIN to do the rear ones haha!
But I am concerned the machine needs it’s feet adjusted even on a flat surface, surely the machine should be “True” Or is this normal?
don wrote:Hi
It just goes to show it’s a good bit of solid kit it is 😉
Adjusting the feet is very easy it’s page 54 of the instruction book.
DonDecember 9, 2015 at 2:51 pm #433359don
ModeratorRe: Can I get a Non Sealed Tub Washing Machine Sub £500?
I would start at the bottom and work up, check the floor level first, left to right and front to back. That will tell you what needs adjusting.
it’s highly unlikely the machine bottom is out of true as the production order is pallet first, then the base panel gets bolted to it and the machine gets built up from there.
DonDecember 9, 2015 at 10:18 pm #433360rustyspoons
Thanks Don,
I pulled the machine out earlier as I hadn’t fitted the non-return valve that was supplied, I need to get a new tap, the one I have the thread isn’t long enough and both the washer hose and the non-return valve requires longer threads, even if I do get it on there I can’t physically turn the tap.
Back to the machine, indeed my floor isn’t level, when I pulled it out it I could rock it over the other corners :boops: And in some parts it is indeed flat.
don wrote:I would start at the bottom and work up, check the floor level first, left to right and front to back. That will tell you what needs adjusting.
DonJanuary 1, 2016 at 10:51 pm #433361madrat
I cant stand this “sealed for life” s#it
Everything is going like it 😡
I can’t understand how it’s more environmentally friendly to throw something away instead of fix it? Recycle is great but re use is much better.
January 2, 2016 at 12:16 am #433362kwatt
KeymasterRe: Can I get a Non Sealed Tub Washing Machine Sub £500?
People want cheap.
That sort of thing is a part of the cost.
