Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Candy Evo 9143D
- This topic has 17 replies, 2 voices, and was last updated 5 years, 7 months ago by
Andonis68.
August 30, 2020 at 12:31 pm #98265
Andonis68
ParticipantHello,
Bit of a strange one this. The washing machine completes a wash cycle successfully when its empty. If we put a load in it the drum fails to rotate. I have taken the motor out and looked at the bushes. they were just above a generous inch and a half in length and looked ok. I cleaned the commutator ring whilst in there.
I have taken the load out and restarted the quick wash cycle whilst its empty and its rotating fine?
Where would the capacitor be to give the motor the extra push it might need under load if it has one?thanks
Tony
August 30, 2020 at 12:36 pm #471620Andonis68
Participantis there another component I need to be looking at to test?
August 30, 2020 at 12:44 pm #471621electrofix
Moderatorthere is only 2 things it can be
the motor or
the control boardbrush motors do not have capacitors
does sound like a motor problem
August 30, 2020 at 12:57 pm #471622Andonis68
Participantthanks Dave I have taken the back cover off to observe. The motor is turning the belt is moving around but the silver central spindal is baggy and just gently rocking side to side as if its slipping. Like a record being held on a turnable slip mat. I am going to see if the fixing is loose.
August 30, 2020 at 1:50 pm #471623electrofix
Moderatorwell the only thing i can think of is the motor mount lugs on the drum have snapped
if thats the case its a wonder the motor has not fallen off
when you say the central spindle are you telking about the motor spindle or the drum pulley ?
August 30, 2020 at 4:45 pm #471624Andonis68
Participantthe motor is working fine. it is like the steel drum is loose under load
August 30, 2020 at 4:51 pm #471625electrofix
ModeratorAH its scrap then
your drum is mounted on a spider which has 3 legs. As there legs corrode they snap and the drum goes out of true when it spins
this is what its like
https://shop.ukwhitegoods.co.uk/1611166-washing-machine-drum-spider-bearing-kitthis one is an old Hotpoint unit but yours is probably a sealed tub and therefore not replaceable
August 30, 2020 at 5:19 pm #471626Andonis68
Participantthere is a circular disc in the middle of the belt pulley with a star bit screw. this was loose. i tightened it up a bit by holding the drum still from the front. its working itself loose and i dont know whats behind it but if sounds like the sprocket teeth are worn or not engaging due to wear and tear. just getting by with a half load at the moment.
August 30, 2020 at 5:21 pm #471627Andonis68
Participantcould do with an exploded diagram
August 30, 2020 at 5:46 pm #471628electrofix
Moderatorsounds like the pulley has gone
we need the long number beginning 3 from the label and i can get you a part no on the pulley
August 30, 2020 at 6:55 pm #471629Andonis68
Participantthe pulley is on espares with a similar question regarding a pully bolt loosening. they replied “Check the bolt securing the pulley and the drum shaft has not been damaged stopping it from tightening.” i will get the part number requested thank you
August 30, 2020 at 6:56 pm #471630Andonis68
Participantcan this puley bolt simply be unscrewed and removed without the drum dropping out of position?
August 30, 2020 at 8:07 pm #471631electrofix
Moderatoryes pulley will not affect drum it cant move forward enough to fall out
still get me the number though in case there is more than 1 pulley
August 30, 2020 at 8:33 pm #471632electrofix
Moderatorif the 3 number is as below
31005184then pulley part no should be 41024466
https://shop.ukwhitegoods.co.uk/41024466-washing-machine-drum-pulleyyou can now do a google search
September 1, 2020 at 8:32 pm #471633Andonis68
Participantthanks Dave. i kept tightening the bolt and asked my misses to be a bit more conscious about the load weight. 4 washes in and it still behaving itself. my misses ordered a new washing machine as she is also fed up of slamming the door to get the magnet lock to engage and lock, i straighten the latch gently.
a theory question : how would the pulley wear to cause the bolt not grip and slip?
are we talking mechanical wear and tear of the bolt housing due to the rotational motion?
the washing machine is about 7 years old and i previously changed the heating element on a previous fault stated on here.
thank you
Tony
