Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Compact Dryers? What make? any good? First time buyer!
- This topic has 17 replies, 8 voices, and was last updated 18 years, 1 month ago by
harty1985.
February 12, 2008 at 7:51 pm #34556
harty1985
ParticipantHi there, moving into my flat soon, I’m after a compact 3kg Tumble dryer as i dont have the space for a full size 1.
Whats the best Value for money, its not going to get a huge amount of use.
Are White Knight any good? Tidied up link
February 13, 2008 at 8:39 am #243117don
ModeratorRe: Compact Dryers? What make? any good? First time buyer!
The White Knight range are about the best out there, easy and relatively inexpensive to repair. Other ones to have a look at are the Hotpoint / Creda machines.
HTH
Don
February 13, 2008 at 5:50 pm #243118harty1985
ParticipantRe: Compact Dryers? What make? any good? First time buyer!
Cheers fella!
will go for 1 of those then, heard bad things about Hotpoint.
February 13, 2008 at 9:29 pm #243119hotpnt
the hotpoint compacts are still hotpoint made, good machines
February 17, 2008 at 11:25 am #243120harty1985
hotpnt wrote:the hotpoint compacts are still hotpoint made, good machines
You mean other Hotpoint machines arnt made by Hotpoint?
February 17, 2008 at 11:32 am #243121kwatt
KeymasterRe: Compact Dryers? What make? any good? First time buyer!
harty1985 wrote:You mean other Hotpoint machines arnt made by Hotpoint?
Nope.
HTH
February 17, 2008 at 12:16 pm #243122WhirlpoolQueen
Back in ye olden days when one worked for NEEB I would have recomended Creda or Jackson as being the most reliable. ‘Course that was in the days of when Creda/Jackson was part of TI Group. (Showing my age)
White Knight made by Crosslee Industries (Old Philips Factory) are also very good & my personal recomendation would be them.As for new generation Creda/Indesit (Asda is flogging one for £85) I really can’t advise, my hunch would be that if it is made by the Merphoney Group stay well clear!!!
WQ
February 17, 2008 at 8:52 pm #243123harty1985
I went into to town today to have a poke about at them.
The hotpoint looks the best, has the vent pipe attachs to the door at the front, ideal for a flat, as i can hang it out of window and detatch it and put it away after.
The White knights are rear vented, so not ideal.February 17, 2008 at 9:35 pm #243124helo_75
Participantsave your money, and get something that doesnt have a serious design flaw, where the only part it needs isnt actually available
rear vented or not, its a better option
February 17, 2008 at 10:04 pm #243125iadom
The only part I ever fit in any quantity on the small Hotpoint/Creda dryer is the belt and I carry a couple of them. The basic machine is virtually the same as it has been for well over 20 years or more. The ultra tight stretchy belt is an absolute pain on all modern dryers but seems to fail more on Hotpoint/Creda/Indesit machines than any other.
February 18, 2008 at 2:09 pm #243126helo_75
Participantand its so dam tight now, it twists the base, and it aint available
had to write a couple off recently
February 18, 2008 at 9:58 pm #243127harty1985
Participanthelo_75 wrote:save your money, and get something that doesnt have a serious design flaw, where the only part it needs isnt actually available
Come again?
You mean the Front vented 1’s are not worth having?
If you saw my flat you would want a front venter though…..February 18, 2008 at 10:16 pm #243128Penguin45
In plain English……..
The two popular compact dryers are the White Knight and the Hotpoint group machines (several different badges, same machine).
The WK machine is a rear vent. Its major weakness is that the drum support/hub bearing unit starts to work loose on the back of the drum, neccessitating the purchase of a new drum as the hub is not a spare part. The latest machines have got rid of the hub and the drum runs on felt slip rings front and rear, which get chewed up with alarming regularity.
The Hotpoint machine is a front vent. Due to cost cutting in production, the belt tensioning mechanism has been removed and an elasticated belt substituted. These fail regularly. Helo has had several where the tension of the belt pulling on the shaft of the motor has buckled the floor of the machine, doubtless causing the belt to run off the motor shaft.
Both machines are a bit cheap and cheerful, as you might expect from the price point – you pays your money and takes your pick.
Penguin45.February 19, 2008 at 2:38 pm #243129WhirlpoolQueen
Penguin45 wrote:In plain English……..
Penguin45.Which is why I mourn the passing of Creda & the TI Group as we once knew it. I wonder how long it will take Merphoney to close down all UK operations and transfer to the People’s Republic of cheap and nasty.
You know dear Penguin you have shocked me to the core when you mention that now White Knight are now “cheaping” their products. I recall the one’s in our showroom were well made and proud to boast with a little label & BS Logo that the drum was made with British Steel.
Sad day. – WQ 🙁
February 19, 2008 at 3:00 pm #243130don
Penguin45 wrote:Both machines are a bit cheap and cheerful, as you might expect from the price point – you pays your money and takes your pick.
Penguin45.Perhaps it`s an opening for an ISE 😉
