Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Diplomat oven ADP 4610
- This topic has 21 replies, 3 voices, and was last updated 4 years, 10 months ago by
Bimbojim.
May 23, 2021 at 6:46 pm #99585
Bimbojim
ParticipantHi all, i am hoping some one can point me in the right direction as to identify this burnt out thermostat for replacement in my Diplomat oven.
There is a “L” shaped plate with two stats on it. One stat has Brown wires coming and going from it and the other(burnt out) has Red wires to each side.
i will post pictures as i appear to have reached my limit on size in this post.May 23, 2021 at 6:49 pm #476991Bimbojim
ParticipantUpload failed due to your usergroup’s upload quota. This file will require 233.4 KB but you only have 19.5 KB of 19.5 KB remaining.
May 23, 2021 at 9:15 pm #476992electrofix
Moderatordue to server constraints we have to ask you host pictures on another site and post a public link
have you looked here ?https://shop.ukwhitegoods.co.uk/catalogsearch/result/index/?p=2&product_list_limit=20&q=ADP4610
May 23, 2021 at 10:05 pm #476993Bimbojim
ParticipantI did see that stat on the web site but I’m not sure if the one I require is the 80° or the 230° stat so that’s why I’m hoping the red or brown wires will help identify the stat. Thanks for the quick response.
May 23, 2021 at 11:54 pm #476994electrofix
Moderatorthe 80 degree one controls the fan but will not stop cooker from working at first but will trip the other stat whwn it overheats.
the other stat stops all functions of the cooker working
May 24, 2021 at 6:16 am #476995Bimbojim
ParticipantThanks Dave, that looks like the 80° one might be the culprit then as the oven heats up then stops heating. Well that link didn’t work, I’ll post picturesfrom my pc this morning.
May 24, 2021 at 6:19 am #476996May 24, 2021 at 6:21 am #476997May 24, 2021 at 6:22 am #476998May 24, 2021 at 7:07 am #476999tubafan
ParticipantHave you partly detached the stat from the metal plate, as if it’s hanging in free air like that it won’t work.
May 24, 2021 at 7:44 am #477000electrofix
ModeratorBimbojim wrote:Thanks Dave, that looks like the 80° one might be the culprit then as the oven heats up then stops heating. Well that link didn’t work, I’ll post picturesfrom my pc this morning.
does the cooling fan start
if no is the cooling fan free to turn ? and does the coil have continuity ?Dave
May 24, 2021 at 9:34 am #477001Bimbojim
ParticipantI checked the stat with the red wires(burnt one) with omhs meter across terminals and didn’t get any response. Do you mean I should recheck the stat Insitu as the plate will be the “earth” ?.
May 24, 2021 at 9:51 am #477002electrofix
Moderatorforget earth
the 80 degree stat will close when it reaches 80 degrees and turns on the cooling fan
if the stat or the cooling fan is faulty then this will not happen and the overheat stat will trip, switching everything offjoin the 2 wires of the stat together. make sure leads cant touch anything and see if the cooling fan runs when you turn on
or put everything back and leave covers off, heat ove up and then turn it off at the mains and see if you get a reading across the stat
May 25, 2021 at 8:47 am #477003Bimbojim
ParticipantH Dave, I did asyou asked with the two wires together the cooling fan started up straight away. The other stat is numbered Z424 R175KS which suggests the R175 is the high temperature one so am I right in thinking that the burnt one must be the 80°c one.
May 28, 2021 at 3:02 pm #477004electrofix
Moderatorthe cooling fan will be the lower temp one
sorry for delay actually got away for a few days
