Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Diplomat oven ADP 4610
- This topic has 21 replies, 3 voices, and was last updated 4 years, 10 months ago by
Bimbojim.
June 1, 2021 at 6:24 am #477005
Bimbojim
ParticipantThanks for the update Dave and glad you got some time away.
I replaced the burnt cut out with a new one and the ” normal oven” top and bottom plates heat up and appear to work as normal along with the cooing fan tripping in about 80-90°.
I then let everything cool down and tried the setting with fan oven selected and again top and bottom started to warm up but rear fan area stayed stone cold.
I next intend to check the rear coil plate with the multimeter to see if it has popped which I didn’t do when i replaced the cut out. You may virtually slap me on the back of the head.
Is there anything I should check after I check the coil (fan spins as normal on fan setting). Thanks for the input, JimJune 1, 2021 at 7:57 am #477006electrofix
Moderatorif fan spins but not heat element is the first place of call
June 12, 2021 at 6:58 am #477007Bimbojim
ParticipantHi all, sorry I haven’t posted back , unfortunately I had a bit of bad luck requiring my right leg being put into plaster from a tumble out walking. And no, I didn’t have rabbit for my tea but if I see it again it will end up in the pot.
I shall get back to the oven near the end of this week as pulling it out onto the kitchen table is a wee bit awkward at the mo
I did check the fan ring and did get continuity with selector switch off then 230 volts after turning temp switch up. For the moment we are using the standard oven set up ( top and bottom elements ) after I replaced the 80°c cut off and is a least giving us use of the oven. Thanks for the help again all.June 12, 2021 at 7:48 am #477008electrofix
Moderator“I did check the fan ring and did get continuity with selector switch off then 230 volts after turning temp switch up”
dont quite know what you mean. continuity tests are made with a 9v meterDave
June 12, 2021 at 9:16 am #477009Bimbojim
ParticipantSorry, I checked the ring with multi meter resistance and it showed no break in ring element and then I switched to boost setting and meter to AC and powered on oven. At that point no voltage showed up until I turned up the temperature dial. The meter immediately showed 230 volts.
Sorry for the confusion Dave.June 12, 2021 at 9:56 am #477010electrofix
Moderatorthats is more confusing
if you resistance across the element and you got 240v across it when on, then it should work
did you check the resistance with one wire disconnected to elimanate any other components altering the reading
June 13, 2021 at 7:56 am #477011Bimbojim
ParticipantAh, that I did not do so I shall check that out next time I pull it out. Again thanks for the delay help Dave.
