Diplomat oven ADP 4610
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Diplomat oven ADP 4610
Viewing 15 posts - 1 through 15 (of 22 total)
  • #99585
    Bimbojim
    Hi all, i am hoping some one can point me in the right direction as to identify this burnt out thermostat for replacement in my Diplomat oven.
    There is a “L” shaped plate with two stats on it. One stat has Brown wires coming and going from it and the other(burnt out) has Red wires to each side.
    i will post pictures as i appear to have reached my limit on size in this post.
    #476991
    Bimbojim
    Upload failed due to your usergroup’s upload quota. This file will require 233.4 KB but you only have 19.5 KB of 19.5 KB remaining.
    #476992
    due to server constraints we have to ask you host pictures on another site and post a public link
    have you looked here ?
    https://shop.ukwhitegoods.co.uk/catalogsearch/result/index/?p=2&product_list_limit=20&q=ADP4610
    Bimbojim
    I did see that stat on the web site but I’m not sure if the one I require is the 80° or the 230° stat so that’s why I’m hoping the red or brown wires will help identify the stat. Thanks for the quick response.
    #476994
    the 80 degree one controls the fan but will not stop cooker from working at first but will trip the other stat whwn it overheats.
    the other stat stops all functions of the cooker working
    Bimbojim
    Thanks Dave, that looks like the 80° one might be the culprit then as the oven heats up then stops heating. Well that link didn’t work, I’ll post picturesfrom my pc this morning.
    #476996
    Bimbojim
    Bimbojim
    Bimbojim
    tubafan
    Have you partly detached the stat from the metal plate, as if it’s hanging in free air like that it won’t work.
    #477000
    Bimbojim wrote:Thanks Dave, that looks like the 80° one might be the culprit then as the oven heats up then stops heating. Well that link didn’t work, I’ll post picturesfrom my pc this morning.
    does the cooling fan start
    if no is the cooling fan free to turn ? and does the coil have continuity ?
    Bimbojim
    I checked the stat with the red wires(burnt one) with omhs meter across terminals and didn’t get any response. Do you mean I should recheck the stat Insitu as the plate will be the “earth” ?.
    #477002
    forget earth
    the 80 degree stat will close when it reaches 80 degrees and turns on the cooling fan
    if the stat or the cooling fan is faulty then this will not happen and the overheat stat will trip, switching everything off
    join the 2 wires of the stat together. make sure leads cant touch anything and see if the cooling fan runs when you turn on
    or put everything back and leave covers off, heat ove up and then turn it off at the mains and see if you get a reading across the stat
    Bimbojim
    H Dave, I did asyou asked with the two wires together the cooling fan started up straight away. The other stat is numbered Z424 R175KS which suggests the R175 is the high temperature one so am I right in thinking that the burnt one must be the 80°c one.
    #477004
    the cooling fan will be the lower temp one
    sorry for delay actually got away for a few days
