Domestic Appliance Testing
Home Forums General Trade Forum Domestic Appliance Testing
Viewing 15 posts - 46 through 60 (of 84 total)
  • #303693
    aclarke
    Re: Domestic Appliance Testing
    hi can you send one to airkool@hotmail.co.uk plz
    #303694
    don
    Done.
    Don
    #303695
    Owain84
    me to please davepricedar@btinternet.com
    Thanks Dave
    #303696
    don
    On it`s way Dave.
    Don
    #303697
    Allsorts
    Martin wrote:I have experienced several have ‘bounced back!’. Hotmail accounts fair the worst I’m sad to say. Seems no Hotmail recipent has gone out and I’m not sure why that is? 💡
    Hotmail!!!!! Maybe the email system thingks it is Hotpoint AKA Indesit LOL …
    Anyways…. Can I have a copy of this seemingly fantastic PDF Martin PLEEEEAAAAASSSSSEEEE!!! 😀 I could do with a good bit of learning from the more knowledgable…. AKA ELDERS 😳
    #303698
    aclarke
    🙁 didnt get mine can u send again to sales@reconwarehouse.com see if this one works as didnt work on hotmail address 🙁 many thanx
    #303699
    Martin,
    Email it to me and I’ll throw it up for download if you want.
    kwatt wrote:Email it to me and I’ll throw it up for download if you want.
    Thanks…check your email. 😀
    #303701
    Ta Martin.
    Download Martin’s document from this link!
    #303702
    kwatt wrote:Ta Martin.
    No problem, my pleasure.:D
    Could I ask if the document will be listed in the downloads section at some stage Ken please? (either in the .pdf docs section or Technical docs maybe?)
    Ta!
    #303703
    Added.
    funkyboogy
    does anyone know of a voltstick type thing that would also give a audible noise ,,, where you could clamp onto appliance cable …
    ally
    #303705
    funkyboogy wrote:does anyone know of a voltstick type thing that would also give a audible noise ,,, where you could clamp onto appliance cable …
    ally
    Hmm. Sounds like an interesting idea screaming out to be invented. So I did a quick Google and found this
    http://cpc.farnell.com/jsp/level5/modul … 345078.xml
    Looks like you’d have to devise your own clamp though.
    Mike.
    #303706
    twicknix
    Can anyone advise me where to get a decent affordable insulation tester?
    I already own a Martindale IN2003 insulation tester. The insulation testing part seems to do what is expected though I am left feeling confused at the readings of being over range. The earth continuity testing part doesn’t seem to work well and I am left wondering if the tester is faulty or am I using it incorrectly. The batteries are fine and in good strength.
    I am using a simple multimeter for earth testing in the meantime not for insulation testing.
    I consulted with Martindale company who assured me that all is well and it is acceptable for PAT testing although they (Martindale) were not familiar with white goods testing. I know from experience that Megger BM221 would provide the results I like but can’t afford their prices. That’s why I opted for Martindale which could may as well be a dumb thing to do. Martindale suggested I get a PAT testing machine which is several times more expensive than what I am using.
    Surely there must be a better way to carry out PAT testing, insulation testing, and earth continuity testing without having to spend several hundreds pounds on few equipments?
    My tester gives a limited range for insulation testing, the maximum is 100 mohms, I know that is very good as it passed the minimum requirement of 2 mohm but I would like an exact reading rather than get a display of “over range” purely to write summat on a paper to prove that it passed with a reading of such n such instead of over 100 mohm. Is it possible for appliance to have insulation readings higher than 100 mohm?
    I am considering to get the tester to checked out by Martindale and have it calibrated. This would means I would have to be slightly out of action as I cannot perform safety checks.
    #303707
    I don’t get mine calibrated. I just try it on a selection of resistors from time to time and if the reading is correct that’s enough to put my mind at rest.
    Have you tried e-bay? There are some mega deals on s/h testing equipment on there usually. Pun entirely intended. 😳
    Mike.
