Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Electrolux Aqualux 1200 Washer/Dryer
- This topic has 24 replies, 8 voices, and was last updated 20 years, 11 months ago by
admin.
April 22, 2005 at 6:56 am #9144
Keymaster😕 I have recently moved into a flat that has a fitted washer dryer. The only problem is that the dryer cycle does not seem to produce any heat into the drum. The top of the machine casing however does warm up which would indicate that a heating element is working but the heat just does not appear to find its way into the drum.
Can you please offer any adviseApril 22, 2005 at 7:05 am #132622Martin
ParticipantRe: Electrolux Aqualux 1200 Washer/Dryer
Allan,
Very likely a few things need to be looked at, the blower fan, inlet valve, condenser ducting etc. Not a DIY job though I would suggest you see if we have someone in your area that can fix it for you (see link below). What is the model number of your machine by the way?
Repairs@Martin
April 22, 2005 at 10:31 am #132623admin
KeymasterRe: Electrolux Aqualux 1200 Washer/Dryer
Hi Martin
Its an Electrolux Aqualux EW 1200 I approx 5 years old.April 22, 2005 at 12:26 pm #132624Martin
Allan wrote:Its an Electrolux Aqualux EW 1200 I approx 5 years old.
That’s OK no problem, my earlier post applies, thanks for the info :tup:
April 26, 2005 at 2:53 pm #132625admin
Yes having checked out the possibilities the blower fan belt had come off. However when replaced it runs at only about 1 rev per second, which is not enough to drive the hot air through. Can you offer any further advice please.
April 26, 2005 at 3:07 pm #132626farmboy
Sounds like you may need a new ventilator (dryer fan)
Theres 2 types so you need to find the serial & product number (PNC)April 27, 2005 at 3:51 pm #132627admin
The serial no is 95200030
Product No is 91467002200
Type P6417395
ThanksApril 27, 2005 at 4:11 pm #132628yurtesen
Participantcan it be that something is stuck and thats why the belt went off at first place?
is the fan difficult to turn ? or the engine of the fan is turning slow even when the belt is not attached..?April 27, 2005 at 4:18 pm #132629RS
Participantjust send him a new washer martin and save time
April 27, 2005 at 4:22 pm #132630Martin
ParticipantRS wrote:just send him a new washer martin and save time
You’ll get a slap in a minute Richard :rotfl:
April 27, 2005 at 4:43 pm #132631yurtesen
😆 I dont know what to say, funny…
April 28, 2005 at 5:49 am #132632admin
A new washer dryer would be very nice but at £500 a time for the luxury of being built in its a non starter for such a small problem.
The blower fan turns freely its the motor that turns slowly with or without the drive belt fitted. What should the rpm of the motor be? What is likely to be the fault? Thanks Allan 😆April 28, 2005 at 7:06 am #132633Martin
Allan wrote:What should the rpm of the motor be?
Not sure of the fan motors speed (1,000rpm maybe?) but quite fast, so if the belt is removed and it runs slower than that, that’s the fault sussed :tup:
A new one can be supplied by emailing us at spares@ukwhitegoods.co.uk
quoting the part number : 1248254102. 😀
April 28, 2005 at 7:49 am #132634Martin
Participantyurtesen wrote:What about the motor? Does it turn freely too?
Allan wrote:its the motor that turns slowly with or without the drive belt fitted.
martin wrote:A new one can be supplied by emailing us at spares@ukwhitegoods.co.uk
April 28, 2005 at 8:29 am #132635AMS
As this is a shaded pole type motor, it should run at a nominal 2800 rpm
