Electrolux E0B 944 tripping out. More advice needed pls
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Electrolux E0B 944 tripping out. More advice needed pls
Viewing 15 posts - 1 through 15 (of 37 total)
  • #70796
    NickStranger
    Built in fan assisted oven. About 8 yrs old.
    It works for bit then cuts out and it’s got a funny smell. I changed fuse on Friday and it was working but it’s gone again today.
    Any ideas? Worth fixing?
    #378950
    Re: Oven problem
    A make and model would help Nick.
    But it does sound like a problem with the cooling fan or fan control thermostat.
    NickStranger
    Re: Oven problem
    Electrolux E0B 944
    #378952
    NickStranger
    Re: Oven problem
    Here’s a pic of the label on by the door, with the model and PNC:
    http://imgur.com/ZrUrD
    Hope this helps.
    Have found on another page that it might be the Thermal Cut Out unit. Should I give it a go replacing it?
    #378953
    Re: Oven problem
    Okay, found it.
    There’s a cooling fan and a fan control stat in that model, that’s it really for that side of things.
    It’s possible that it’s the thermostat that’s the problem but the symptoms you describe are more consistent with the cooling fan failing or failed and the thermostat doing its job and shutting the oven down.
    The cooling fan is here so you know what to look for:
    http://shop.ukwhitegoods.co.uk/33700002 … -fan-motor
    HTH
    NickStranger
    Re: Oven problem
    Thank you.
    Is the cooling fan easy to replace myself???
    #378955
    Re: Oven problem
    Not too bad to do I shouldn’t think.
    NickStranger
    Re: Oven problem
    Where roughly on the oven would it be? Would it be as simple as it would be to change that Thermal cut out unit, ie pull it out a bit and take the top off??
    #378957
    Re: Oven problem
    Pretty much, yes.
    NickStranger
    Re: Oven problem
    Thanks for the advice.
    Have ordered and will report back.
    #378959
    NickStranger
    Re: Oven problem
    Hi.
    I ordered the cooling fan and installed it, and although the outside of the unit is cooler now, it is still cutting out after 15-20 mins.
    Any ideas???
    #378960
    Re: Oven problem
    There is a thermal cut out which has 2 white wires and 2 blue wires that are in a plastic tube normally on the left middle towards the front. This will have normally failed if the fan had previously gone. It senses the temprature and cut off if it gets too hot or thinks it has.
    Bryan
    #378961
    NickStranger
    Re: Oven problem
    r600a wrote:Hi
    Bryan
    Thank you.
    Do you have a link to a product I can order???
    #378962
    Re: Oven problem
    I’ in the middle of no where at the moment with just my phone but I’m sure ken could find it for you.
    Bryan
    #378963
    NickStranger
    Re: Oven problem
    r600a wrote:I’ in the middle of no where at the moment with just my phone but I’m sure ken could find it for you.
    Bryan
    Any ideas Ken?
