Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Electrolux E0B 944 tripping out. More advice needed pls
- This topic has 36 replies, 5 voices, and was last updated 13 years, 8 months ago by
NickStranger.
August 12, 2012 at 9:58 am #378964
NickStranger
ParticipantElectrolux E0B 944 tripping out. More advice needed pls
Hi.
I posted this in the GENERAL section last week, but this seems to be a busier place, so reposting here in the hope of more help.
Built in fan assisted oven. Electrolux E0B 944. About 8 yrs old.
It works for bit then cuts out and it’s got a funny smell. I changed fuse on Friday and it was working but it’s gone again today.
Any ideas? Worth fixing?
Label here: http://imgur.com/ZrUrD
It was suggested I replace the COOLING FAN MOTOR, which I did, and although the surround is now cooler, it is still tripping after 15 minsutes or so.
It has also been suggested I change the thermostat, but would appriciate a link to a specific product, if anyone can suggest one.
August 12, 2012 at 12:18 pm #378965admin
KeymasterRe: Oven problem
http://shop.ukwhitegoods.co.uk/89966192 … an-control
Do you have one of these in your oven ?
Bryan
August 12, 2012 at 4:23 pm #378966NickStranger
ParticipantRe: Oven problem
r600a wrote:http://tinyurl.com/cvhaa8h
Bryan
I don’t think so…. eek
Earlier in this thread someone said
There’s a cooling fan and a fan control stat in that model, that’s it really for that side of things.
Is that the fan control stat you linked to?
August 12, 2012 at 5:56 pm #378967kwatt
No that fan control stat isn’t used in that oven, it’s a different one but I don’t have access to the info here on the one that is used.
I’ll get Dave to have a look and post the right one or try to remember to do it when I get into the office tomorrow.
August 12, 2012 at 6:01 pm #378968NickStranger
kwatt wrote:No that fan control stat isn’t used in that oven, it’s a different one but I don’t have access to the info here on the one that is used.
Thank you. Appreciate it.
August 12, 2012 at 6:23 pm #378969jimca007
ParticipantRe: Electrolux E0B 944 tripping out. More advice needed pls
more likely to be the element. the element is basically a length of wire incased in chalk and wrapped in an outer metal case. Often the chalk will either start to break down or absorb moisture giving a path to earth. Its not unusual for a cold element to test fine and yet show a consideably reduced insulation reading when hot.
August 12, 2012 at 6:26 pm #378970NickStranger
jimca007 wrote:more likely to be the element. the element is basically a length of wire incased in chalk and wrapped in an outer metal case. Often the chalk will either start to break down or absorb moisture giving a path to earth. Its not unusual for a cold element to test fine and yet show a consideably reduced insulation reading when hot.
Thanks.
Do you have a link to a specific product I could buy that would fit the unit?
August 12, 2012 at 6:31 pm #378971jimca007
DST3871425108 is the part number for a genuine part but an equivelent pattern part would be much cheaper just rattle the model number and fan element into google you’ll get the part no prob
August 12, 2012 at 6:33 pm #378972NickStranger
Thank you.
August 12, 2012 at 6:33 pm #378973admin
KeymasterRe: Electrolux E0B 944 tripping out. More advice needed pls
Just a question..
Does the WHOLE oven cut off as in no power,no display or is it that the cooling fan stops or the element stops ?
Bryan
August 12, 2012 at 6:35 pm #378974NickStranger
Just the heat.
August 12, 2012 at 6:39 pm #378975jimca007
em that could be different I read that as ” tripping out ” and its cutting out. Could well be your variable thermostat
August 12, 2012 at 6:41 pm #378976NickStranger
Thanks. On the case.
August 20, 2012 at 2:22 pm #378977NickStranger
UPDATE:
So I’ve changed the internal COOLING FAN, and it is still tripping.
It’s CUTTING ALL POWER when it trips.
So could it be the ELEMENT that is faulty, or the thermostat???
Pics below of the internal top:
http://imgur.com/2LGO1
http://imgur.com/YuVx9
http://imgur.com/93HGkAugust 20, 2012 at 2:38 pm #378978kwatt
You’d need to megger the elements to test for leaks to earth Nick. 😕
If it’s really bad just seeing if you get anything between the live and neutral posts with even a basic multi-meter might work but, it’s got to be really bad to see that.
