Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Electrolux E0B 944 tripping out. More advice needed pls
- This topic has 36 replies, 5 voices, and was last updated 13 years, 8 months ago by
NickStranger.
August 5, 2012 at 8:57 am #70796
NickStranger
ParticipantBuilt in fan assisted oven. About 8 yrs old.
It works for bit then cuts out and it’s got a funny smell. I changed fuse on Friday and it was working but it’s gone again today.
Any ideas? Worth fixing?
August 5, 2012 at 9:10 am #378950kwatt
KeymasterRe: Oven problem
A make and model would help Nick.
But it does sound like a problem with the cooling fan or fan control thermostat.
August 5, 2012 at 9:20 am #378951NickStranger
ParticipantRe: Oven problem
Electrolux E0B 944
August 5, 2012 at 10:06 am #378952NickStranger
Here’s a pic of the label on by the door, with the model and PNC:
Hope this helps.
Have found on another page that it might be the Thermal Cut Out unit. Should I give it a go replacing it?
August 5, 2012 at 10:25 am #378953kwatt
Okay, found it.
There’s a cooling fan and a fan control stat in that model, that’s it really for that side of things.
It’s possible that it’s the thermostat that’s the problem but the symptoms you describe are more consistent with the cooling fan failing or failed and the thermostat doing its job and shutting the oven down.
The cooling fan is here so you know what to look for:
http://shop.ukwhitegoods.co.uk/33700002 … -fan-motor
HTH
August 5, 2012 at 10:28 am #378954NickStranger
Thank you.
Is the cooling fan easy to replace myself???August 5, 2012 at 10:30 am #378955kwatt
Not too bad to do I shouldn’t think.
August 5, 2012 at 10:32 am #378956NickStranger
Where roughly on the oven would it be? Would it be as simple as it would be to change that Thermal cut out unit, ie pull it out a bit and take the top off??
August 5, 2012 at 11:02 am #378957kwatt
Pretty much, yes.
August 5, 2012 at 11:07 am #378958NickStranger
Thanks for the advice.
Have ordered and will report back.August 11, 2012 at 4:18 pm #378959NickStranger
Hi.
I ordered the cooling fan and installed it, and although the outside of the unit is cooler now, it is still cutting out after 15-20 mins.Any ideas???
August 11, 2012 at 8:23 pm #378960admin
There is a thermal cut out which has 2 white wires and 2 blue wires that are in a plastic tube normally on the left middle towards the front. This will have normally failed if the fan had previously gone. It senses the temprature and cut off if it gets too hot or thinks it has.
Bryan
August 11, 2012 at 8:34 pm #378961NickStranger
r600a wrote:Hi
Bryan
Thank you.
Do you have a link to a product I can order???
August 11, 2012 at 8:46 pm #378962admin
I’ in the middle of no where at the moment with just my phone but I’m sure ken could find it for you.
Bryan
August 12, 2012 at 8:11 am #378963NickStranger
r600a wrote:I’ in the middle of no where at the moment with just my phone but I’m sure ken could find it for you.
Bryan
Any ideas Ken?
